Results 1 to 5 of 5
Reload Thread: new door idea PLUS need input on low wattage components
    RoudyruffKK's Avatar
    RoudyruffKK is offline Member
    Sep 2005
    Fremont, CA
    31
    47
    ok as most of you know i'm pretty unsatisfied with my current midbass. it's not really that i'm unsatisfied i feel that it's lacking. check my sig for my equipment but i feel like the HD mids although sound amazing just aren't cutting it in the lower spectrum say sub 120hz and i'm currently running an active setup
    i've thought about changing out the midbasses or adding a dedicated midbass, but IMO i think that it's going to cost way too much to fiberglass an 8" + another amp (which i don't have room for). RIGHT NOW I"M LOOKING FOR A HIGH EFFICIENCY COMPONENT SET. tell me if this would work well..... get a set of components that will be efficiently powered by 100rms/side (channels 1/2) then get a set of 6.5" dedicated midbasses (something along the lines of 100rms @ 4ohm or 200rms @ 2ohm, that's what my amp puts out in channels 3/4). i don't think it would be too hard to fabricate 6.5" in the door. i'm looking for sql mostly sq with the ability to get loud if i want it to.
    now would my amp be sufficient in that setup/will this work? recommend me speakers that would work best in this setup, with the given power i have to work with. right now i'm thinking:
    COMPONENTS - alpine SPX-177R: i've heard people say 60-70rms is perfect for it but i'm not sure if they meant perside or per driver (60rms for mid, 60rms for tweeter or is it just 60rms for the whole side). also their site also states that the crossover is "3-Way/Dual Midbass Ready" and "Bi-Amp/Bi-Wire Capable" i won't be biamping them because i only have 2 channels to work with, and i won't need the 3way option because each midbass will have it's own dedicated channel so in a way i'm "biamping" because basically i have on driver from 60hz-250hz(mid) and another "driver"(components) that go from 250hz-20khz. IS THAT HOW IT WOULD GO? I"M UNSURE IF IT WOULD WORK THAT WAY
    MIDBASS- re xxx 6.5": lots of midbass (it's what i'm looking for)
    hu: alpine cda-9855
    front mid: cdt hd-6
    front high: cdt drt-26 silk
    front amp: alpine mrv-f345
    rear fill: cdt-6e
    sub: ascendant audio avalanche 15"
    sub amp: arc audio kar900.1d
    alarm: viper 791xv
    dampening: dynamat xtreme 48sqft (all panels inside and out except roof and floor)
    bikejunkie223's Avatar
    bikejunkie223 is offline Dls Wh0re
    Sep 2005
    Salem, OR
    38
    1,955
    Re: new door idea PLUS need input on low wattage components
    Have you tried sound deadening the doors where your 6.5's are? I had some Polk db 6500 components that were really lacking in midbass and was going tobuy a new amp, but on a dealers suggestion, we sound deadened the doors with Cascade, sealed them up well, and in made an absurd difference. I would try that first, I was floored at the results in my car.
    Shop smart...Shop S-Mart... YOU GOT THAT!!!!!!!!
    salsa shark....
    Current Setup:
    Vehicle: 2004 Honda Civic Si
    Head: DEH 860MP
    Mid/High: Dls UP-6
    Subs: Dls Iridium 10
    Amp: Xtant 403a
    Other:Valentine 1 radar detector with remote display, Pioneer ipod controller, XM sat radio, Rear fill was determined to be a part of a communist plot to destroy our way of life and was henceforth banished from my car
    Sep 2005
    Fremont, CA
    31
    47
    Quote Originally Posted by bikejunkie223
    the door's are deadened both sides with dynamat extreme, still doesn't have the authority in the kicks as i would like, i'm going to check the speaker wire to the amp to see if they are out of phase. i don't think that's the problem because without my sub the midbass is there just that when i put the sub back in it almost feels nonexistant because the sub hits so hard the midbass isn't keeping up
    hu: alpine cda-9855
    front mid: cdt hd-6
    rear fill: cdt-6e
    alarm: viper 791xv
    SSS 18734's Avatar
    SSS 18734 is offline Dollar Menu Millionaire
    Mar 2005
    Kansas City, MO
    5,457
    Quote Originally Posted by RoudyruffKK
    turn the sub down a bit?
    also, ur sig says you have 48sq ft of dynamat installed everywhere in your car except the roof and floor... that doesn't leave much room for deadening the doors. From what i've heard you should aim for about 20 sq.ft. per door and you should seal up the holes in order to really get good results.
    Bought From:
    Absolutnockout, zachzchw, Untouchable11, j3bus2k3 (x2), 92c1v1c, jeeper07, acubsfan, bkjt05, Goldenknob, Goindef154, Basscourt2009, TeamSouthrnBass, oldschoolboomer, 99grandprixGT
    Sold to:
    Gearguy2001 (American Bass SQ780)
    Tw1st3d13 (2 Fi BL 15's)
    Sep 2005
    Salem, OR
    38
    1,955
    Quote Originally Posted by SSS 18734
    That's what I'm sayin' The only holes in my door skin is the one the speaker goes in. Just don't fill up your door with packing material like some ******* did in a Ford Escape that was traded in last week. The friggin' windows wouldn't roll down. Idiot=whoever did that.
    salsa shark....
    Current Setup:
    Head: DEH 860MP
    Mid/High: Dls UP-6
    Amp: Xtant 403a
  1. Review: RE Components
    By Randy Savage in forum General Discussion
    Last Post: 11-14-2004, 08:27 PM
  2. Resonant engineering, RE 6.5 Components
    By valant_94gt in forum Subwoofer and Speaker Reviews
    Last Post: 09-11-2004, 08:03 PM
  3. Replies: 4
    Last Post: 08-15-2004, 04:26 PM
  4. Comps **** at low power?
    By maylar in forum General Discussion
    Last Post: 06-23-2003, 05:01 PM
  5. Input sensitivity
    By blitz459 in forum Amplifiers
    Last Post: 05-15-2003, 11:44 PM
