with that autotek from snoop the nightsshade would be wired at 1 ohm so around 1400 watts.. i will probalbly take him up on that.. might not do to bad.. And I will just run whichever Amateur class I fit in with (2) 20 amp fuses
2000 Ford Explorer
Team Innovative
Team Sundown
2009 MECA AS2 Ky State Champion -- 147.3
2009 MECA AS2 World Champ -- 147.7
Refs:
http://www.caraudio.com/forum/showth...42#post5779442
Bought from -- loudcartunez, Second Skin Rep, CRXBMPN, Dbeez, 99grandprixGT, Lakota, wgsj_fortvalley, Sundownz,dman4486, thegreatestpenn
Sold To -- DukeNut, runwitbass, thegreatestpenn, jpeaslee,jeep2000, TnT_Sounds,satchel50207
Traded With -- Dbeez, infamous_e46,thegreatestpenn
13. Competitors may only compete in one (1) “Pressure Class” per Format (i.e. SPL, “Drive-by SPL Parade”, or
SQL) at an event.
2002 suburban
Security System Code alarm
Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit pioneer 880prs
Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
Wiring lots of 1/0 stinger, tsunami
Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
Subs 4-18" nightshade v2's d2
System DetailsDaily driver.
With a single 15, in AS1 you get 40 or 50 amps of fusing with in 20"in of the amp. I forget because its been 2 years. Either way i could play on 40 amps all day. Maxi's were the best.
2013 Hyundai Elantra GT
05,06 2x IL/Wi Record Holder
06 2x Meca World Finalist
2000 Ford Explorer
Team Innovative
Team Sundown
Refs:
Team Kicker (R.I.P.)
Team Sundown
Team Maxxsonics
Team XS Power
Team DD
Team Audio Technix
Team B2 Audio
Team Mechman
2008 Bassrace 130-139.9 Regional and National Champion
2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, DB1, S2, S3, S4)
One DD 9510 powered by two Sundown SAZ-2500's
Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
Kicker wiring throughout.
You can't borrow equipment either in AS.
Team Carlisle Acoustics - Team Sundown Audio
2010 MECA DB3 World Champ 127.2
2010 MECA DB3 KY State Record 127.3
2009 February MECA Member of the Month
2008 MECA DB2 World Champ 131.9db
2008 MECA DB2 KY State Record 129.1
2008 MECA Neighborhood Nuisance
2007 MECA AS2 KY State Record 144.2
Ben Hemp
1992 GMC Sonoma Ext Cab NEW BUILD
2008 MECA S1 KY State Champion, 151.0 dB
2008 MECA S1 WorldChampion, 151.8 dB
2010 MECA scores: 150.9 dB S2, 151.6 dB S3
Refs: smd4life, Subst4nce, wccoug21, dacheatham, thegreatestpenn, jshak07
Team Sundown
Team Maxxsonics
Team XS Power
Team DD
Team Audio Technix
Team B2 Audio
Team Mechman
98% sure I'll be there![]()
<First and only dual-alternator 'real' Saturn (pre 2002) on the planet>
Team Concepts, Team Shok Industries Team XS Power
Soon: Mystery subs + AQ20k
12.75 cubes net ~25Hz tuning 200 sq inches of port (lowz?)
AC position- 250 amp alt
Stock alt position- 225 amp alt
(2) XS Power D3100's
4 power+ 4 ground runs of 1/0-gauge to rear
152.1 @ 40Hz legal, certified...just getting started.
Ben Hemp
Ben Hemp
Ben Hemp
Seems like a cool show. Maybe one year down the road Ill make the trip.
Team Sundown
Team Maxxsonics
Team XS Power
Team DD
Team Audio Technix
Team B2 Audio
Team Mechman
Bookmarks
