i only did a 155.8 on the ac.![]()
REFS =adam007,guy022077(X2),ga12r,cd6551,dbman150(x2),( x2)louisiana_crx,ent3rdadragon,baseballer1100(x3),
smd4life,i3abyjay25,bigblank69,bigsherm7272,squeak 12,mike dressure,ngsm13,grassroots,ricksmx01,ionSQL(x2),wh osaywho?,nhustlar,lilman,ryanm923,pioneerpimp,blaz eplacid,mystang,profoundwill,bumpin buick,sean dub,Zeuslicious,jared spl,jailhouseracer8,queball,2002xlt,bigbangtheory, jared530,(x2)skip01,ringo,skadude016,daghost, Cornbreadxd, blackstar602,ssackett,yunvme666, tv559,XxSuperAdamxX ,hellfire,deez283,Flastrongman,
TEAM DB UNIT FTMFW!
thanks man... i wish i recorded my own run, my rear view mirror broke off from the windshield as soon as i unpaused it...
yeah, the amp made a huge difference this time around, but i also had my EQ set all the way negative last time... oops... edit: had it set to flat today
i have it wired up at .5 now and it will make the sxs stink pretty quick. i just keep the sub level below -10... mm3000.1's are beasts, couldn't be happier with it, thanks again...
i plan on coming to tifton, and i'll see if the local shop here will let me stick up a flyer...
refs: got em
Team LBs Audio
Deck- Eclipse AVN6600
Front comps- Image Dynamics CXS62
Rear comps- Image Dynamics CXS54
Component Amp-Autotek MM100.4
Sub amp- Autotek MM4000.1
Subs- (2) RE SX12s
Battery- Stinger SP1700
Alt-Iraggi 280
Wiring- 2 runs Stinger Expert 1/0
Possibly the loudest Cadillac CTS on the planetWhich isnt saying much
RE Audio,US AMPS,AUTOTEK,IMAGE DYNAMICS,KICKER,ECLIPSE,KINETIK,STINGER
Refs: cmoney585, matrxx dude,bvr_j_0969,oxsign
Ebay Seller ID: ga12r
your eq would have made no difference because when i test a vehicle i keep going with the volume until the meter stops ganing,and thats the way i metered you today and last time,all the eq does is make the meter get there fater without having to turn the volume up more,but when you running testones its better to have everthing flat.
TEAM DB UNIT FTMFW!
i heard autotek was the high end line by maxxsonics now.
TEAM DB UNIT FTMFW!
Team LBs Audio
Subs- (2) RE SX12s
Alt-Iraggi 280
lol
TEAM DB UNIT FTMFW!
ah, okay...
i'll have to think of something intelligent to write and post up a review sometime, haha... i still haven't even messed with it at all, can't wait to get off work tomarrow and put a hurtin on those subs![]()
refs: got em
Did Skadude run his new setup? How did he do, compared to his old setup?
Team LBs Audio
Subs- (2) RE SX12s
Alt-Iraggi 280
i don't think he was too happy with his 187's... his death penalty 15 did better...
refs: got em
his fifteen actually done better than the 4 12's,skadude just needs some more power.
TEAM DB UNIT FTMFW!
the ole merlin just aint enough.lol
TEAM DB UNIT FTMFW!
grassroots if i was you i would run them subs at 2 ohm daily,still should be awful loud.
TEAM DB UNIT FTMFW!
Team LBs Audio
Subs- (2) RE SX12s
Alt-Iraggi 280
he done like a 43.9
TEAM DB UNIT FTMFW!
Bookmarks
