Page 7 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 91 to 105 of 184
Reload Thread: Dec. 10th Carollton, GA 3x Event
  1. #91
    matrxx dude's Avatar
    matrxx dude is offline TEAM DB UNIT
    Feb 2006
    tifton ga
    42
    6,388
    14
    Re: Dec. 10th Carollton, GA 3x Event
    alright ill be looking for ya
    REFS =adam007,guy022077(X2),ga12r,cd6551,dbman150(x2),( x2)louisiana_crx,ent3rdadragon,baseballer1100(x3),
    smd4life,i3abyjay25,bigblank69,bigsherm7272,squeak 12,mike dressure,ngsm13,grassroots,ricksmx01,ionSQL(x2),wh osaywho?,nhustlar,lilman,ryanm923,pioneerpimp,blaz eplacid,mystang,profoundwill,bumpin buick,sean dub,Zeuslicious,jared spl,jailhouseracer8,queball,2002xlt,bigbangtheory, jared530,(x2)skip01,ringo,skadude016,daghost, Cornbreadxd, blackstar602,ssackett,yunvme666, tv559,XxSuperAdamxX ,hellfire,deez283,Flastrongman,
    TEAM DB UNIT FTMFW!
  2. #92
    squeak12's Avatar
    squeak12 is offline CarAudio.com Veteran
    Apr 2005
    Thomaston, GA
    3,673
    I used 4" Aeros
    What the hell did you say ska?
    Finished the install
    Exterior:
    Interior:
  3. #93
    skadude016's Avatar
    skadude016 is offline CarAudio.com Veteran
    Feb 2003
    Canton, GA
    27
    7,319
    13
    im lost... what are u talking about Chris? lol
    HU:Kenwood Excelon KDC-889
    Speakers: CDT 61A's with rainbow x-overs
    Front amp: Autotek MM100.4
    Sub amp: (2) Audiopipe 1500's
    Subwoofers: (4) 15" Crunch GPV
    Box: 16 cubes tuned to 28hz (removable port)
    Extra Batt: C&D 139AH
    151.xx sealed up 154.xx in the kick
  4. #94
    Feb 2006
    tifton ga
    42
    6,388
    14
    squeak you tested it any yet?
    TEAM DB UNIT FTMFW!
  5. #95
    squeak12's Avatar
    Apr 2005
    Thomaston, GA
    3,673
    No, I worked until 5.30 today and then it was dark and COLD. Im going to finish tomorrow. I get off at 12.30 and got all day to do two small things. Should be done by 2 EASILY.
  6. #96
    Feb 2006
    tifton ga
    42
    6,388
    14
    better fire it off and make sure all is fine.
    TEAM DB UNIT FTMFW!
  7. #97
    squeak12's Avatar
    Apr 2005
    Thomaston, GA
    3,673
    Unless something is wrong in the rex, it should be fine. I used the subs box and amps in my car for a test the other day.
  8. #98
    Feb 2006
    tifton ga
    42
    6,388
    14
    sound good
    TEAM DB UNIT FTMFW!
  9. #99
    squeak12's Avatar
    Apr 2005
    Thomaston, GA
    3,673
    Well I just finished it all except the remote wire. I gotta go get some spade connectors for the switch and then Ill be done.
    Ports back was too hard to load the box in by myself, so Ill probably leave it like that, not sure though.
  10. #100
    peteyglad's Avatar
    peteyglad is offline Member
    Aug 2004
    Atlanta, GA
    81
    I would try to get ports back or even to the side if you can. I have seen 2 db jump between having the ports firing forward and then pointing them to the side.
    98 Saturn SL2
    Alpine CDA-9856
  11. #101
    squeak12's Avatar
    Apr 2005
    Thomaston, GA
    3,673
    Well it works. I tested it on the radio since I haven't made a CD yet. Also I locked the keys in it, but I'm a hella crook and saw something in the door when I popped some molding off. Looked like it needed to be pushed and when I did, it unlocked the door
    Well I'm about to burn a cd, flip the box around and extend the speaker wire with wire nuts.
  12. #102
    Feb 2006
    tifton ga
    42
    6,388
    14
    good job squeak,heres my score on the term i done today during testing,db drag style,engine off,legal on the dash.
    TEAM DB UNIT FTMFW!
  13. #103
    squeak12's Avatar
    Apr 2005
    Thomaston, GA
    3,673
    Will someone there have some sweeps? My burner wont burn the ones on ROE. I just need 50-70
  14. #104
    Feb 2006
    tifton ga
    42
    6,388
    14
    i got some sweeps,and by the way why is one aero port longer than the other one.
    TEAM DB UNIT FTMFW!
  15. #105
    squeak12's Avatar
    Apr 2005
    Thomaston, GA
    3,673
    A variation of a 6th order bandpass.
