Results 1 to 2 of 2
Reload Thread: PRE-ORDER : Skar Audio T-Series Amplifiers (Ends Oct 20th) - 4 NEW MODELS
    SkarAudio's Avatar
    SkarAudio is offline CarAudio.com Elite
    Oct 2010
    Florida
    788
    180 Post(s)
    We are happy to announce that the "T-Series" amplifiers are only about 8 days from arriving to our facility to start shipping out. They will be fully in stock in 8 days as stated, and for a limited time only (Today through Thurs Oct 17th) you can PRE-ORDER them at a super special price that will never be available after this week.
    The T-Series was founded on the principal of us wanting to design a 5 channel amplifier independent of our other lines and offer it at a reasonable price. With that being said, there are two new 5 channel amplifiers in this series as well as two monoblocks. The 4 new models in this series are all very well built, high performance, and conservatively rated amplifiers. They also feature several nice design features, such as Tiffany RCA connectors, blue LED Lighting, and a very efficient heat sink for maximum heat dissipation.
    PRE-ORDER Information
    In Stock : October 18th
    End of Pre-Order : October 17th
    T Series Amplifiers by Skar Audio
    T-1400.1D Monoblock
    T-2000.1D Monoblock
    T-60.4-200.1AB 5 Channel
    T-60.4AB-500.1D 5 Channel
    Free Shipping on ALL Pre-Orders in the USA - DON"T MISS OUT ON THIS 1 WEEK SPECIAL PRICING!
    T-1400.1D Pre-Order Price = $260.00 (Normal MAP = $330.00)
    T-2000.1D Pre-Order Price = $450.00 (Normal MAP = $550.00)
    T-60.4-200.1AB Pre-Order Price = $260.00 (Normal MAP = $330.00)
    T-60.4AB-500.1D Pre-Order Price = $330.00 (Normal MAP = $400.00)
    To Order :
    Please either visit our website and the specific product age of each amplifier to pre-order - or paypal the correct payment amount to [email protected] and leave a note. All Pre-Orders will ship the same day the new models arrive, which is Friday Oct 18th. The Pre-Order will end the very next day and pricing will go up to normal full MAP.
    T-1400.1D Technical Specifications
    RMS Power @ 1 Ohms : 1400 Watts x 1 CH
    RMS Power @ 2 Ohms : 700 watts x 1 CH
    RMS Power @ 4 Ohm : 350 Watts x 1 CH
    Frequency Response (-3dB) : 10Hz~250Hz
    Input Sensitivity : 6V~0.2V
    Low Pass Filter : 50Hz~250Hz
    Bass Boost (Variable) : 0dB~12dB
    Signal to Noise Ratior : 100dB
    Damping Factor : ~180
    Fuse Rating : 40 Amp x 3
    Remote Gain Control Included with Knob
    Line-In RCA Connection
    Line-Out RCA Connection
    4 Way Protection Circuitry
    Dimensions : 250mm x 53mm x 340mm
    T-2000.1D Technical Specifications
    RMS Power @ 1 Ohms : 2000 Watts x 1 CH
    RMS Power @ 2 Ohms : 1000 watts x 1 CH
    RMS Power @ 4 Ohm : 500 Watts x 1 CH
    Fuse Rating : 200 Amp (External)
    Dimensions : 480mm x 53mm x 340mm
    T-60.4-200.AB Technical Specifications
    RMS Power @ 1 Ohms : N/a
    RMS Power @ 2 Ohms : 80 Watts x 4 CH + 350 Watts x 1 CH
    RMS Power @ 4 Ohm : 60 Watts x 4 CH + 200 Watts x 1 CH
    Frequency Response (-3dB) : 10Hz~40kHz
    Low Pass Filter : 50Hz~500Hz
    High Pass Filter : 80Hz~4kHz
    Subsonic Filter : 15Hz~50Hz
    Fuse Rating : 30 Amp x 3
    Dimensions : 250mm x 53mm x 420mm
    T-60.4AB-500.1D Technical Specifications
    RMS Power @ 1 Ohms : N.A. (4CH) + 500 Watts x 1 CH
    Frequency Response (-3dB) : 10Hz~40kHz (4CH) 10Hz~250Hz (5CH)
    5th Channel is 1 Ohm Stable (4 CH is 2 Ohm Stable)
    Dimensions : 250mm x 53mm x 400mm
    Pictures
    Kevin Schlenker
    CEO - Skar Audio
    www.SkarAudio.com
    Email : [email protected]
    Phone : (888) 501-7527
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    WA
    32
    3,623
    1703 Post(s)
    Re: PRE-ORDER : Skar Audio T-Series Amplifiers (Ends Oct 20th) - 4 NEW MODELS
    Meh.
    Kudos to you adding in the Tiffany RCAs as I wish more companies would offer something as robust, but I wouldn't call that heat sink "efficient." Metal? Yes. But not a whole lot of surface area for dissipation. Instead of focusing on how efficient the heat sink is, don't you think there would be more merit in reducing heat losses from that Class D design?
    Spotify: http://open.spotify.com/user/neo_styles/playlist/6t9ru42j0wbEsuo4bXqXD8
  3. Likes macsdad liked this post
  • You may not post replies
