Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 47
Reload Thread: Under-rated @ 600w...
    Cinderella's Avatar
    Cinderella is offline No bewbies for you..
    Mar 2012
    Middle-of-Nowhere, IA
    218
    7 Post(s)
    So, if the SKAR VVXs are considered underrated at 600w RMS, what do you guys think would be a good amount of power to give them daily?
    I plan on buying 1 15" sub, and throwing it in a box that's giving the sub 3.0-3.2 cubic feet of space.
    Music is Life.
    GAMEOVERCCA's Avatar
    GAMEOVERCCA is online now INCRIMINATOR AUDIO
    Jun 2011
    Hickory NC
    1,726
    10 Post(s)
    Re: Under-rated @ 600w...
    skars are underrated at 600, but keep in mind there not underrated like a SA15 or a LI15.. id say 800rms daily is tops i would give it safely..
    Subs
    2 IA Death penalty 15's
    Highs and Mids
    2 IA Comp sets
    Amps
    1 AB VFL200.1
    1 Mmats SQ4150
    Batteries
    3 Deka intimidator 1000amp 100ah AGM's
    Isaac's Avatar
    Isaac is offline Member
    Mar 2012
    Iowa
    72
    I've seen videos of people puting 1000-1500 watts to each of them. Clean power though
    Cinderella's Avatar
    Mar 2012
    218
    7 Post(s)
    I'm thinking of giving it 900w @ 2 ohms and just being careful with the gain..
    Music is Life.
    murph's Avatar
    murph is offline Low for Life
    Sep 2011
    Richmond,VA
    3,485
    89 Post(s)
    Make sure that box is built well. If the sub is facing up in that trunk you will not be too happy.
    Hu: kenwood kdc-x995
    Sub: Boston acoustics G5 12 in a quasi 6th order
    Amp: Eclipse Xa5000
    Front Speakers: Eclipse sc6500
    HIT UP FOR BASS ---> http://www.youtube.com/user/BassWithMurph?feature=mhee
    Jun 2011
    Hickory NC
    1,726
    10 Post(s)
    clean power is hard to come buy, and not daily.. still killer subs for there price point
    Subs
    Highs and Mids
    2 IA Comp sets
    Amps
    1 AB VFL200.1
    1 Mmats SQ4150
    Batteries
    Isaac's Avatar
    Mar 2012
    Iowa
    72
    Quote Originally Posted by GAMEOVERCCA View Post
    Yeah that's true. Daily probably 800-1000 maybe. What amps are you looking at?
    murph's Avatar
    Sep 2011
    Richmond,VA
    3,485
    89 Post(s)
    Also get an amp that does 1k at 2ohms that is because after voltage loss, box rise, and so on you will not get that much power going to it.
    Amp: Eclipse Xa5000
  9. #9
    Jun 2011
    Hickory NC
    1,726
    10 Post(s)
    you can cure alot of that issue of rise with, big 3 upgrade, direct leads to sub (no terminals or cups) and upgrade to a better agm battery under hood. that will cut your rise big time.. i have done the testing and just thoughs 3 things cut voltage loss and ohm rise in half if not more.
    Subs
    Highs and Mids
    2 IA Comp sets
    Amps
    1 AB VFL200.1
    1 Mmats SQ4150
    Batteries
  10. #10
    Falcons's Avatar
    Falcons is offline that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,099
    17 Post(s)
    hi tristan!
    Things to look forward to:
    (2) 10" or 12" imperium audio designs subs
    set of PHD MF 6.5" comps
    Completely seal off and deaden my doors
    aquire a 2k amp
    aquire a 2 channel amp for front stage
  11. Likes CAT MAN liked this post
  12. #11
    UnderFire's Avatar
    UnderFire is offline CarAudio.com Elite
    Apr 2011
    Dayton, OR, 97114
    1,750
    26 Post(s)
    I think the BRZ is a great match for the Skar's, it doesn't push rated, but in this case that's a good thing.
    97 4runner, 3RZ, 5 Speed
    Headunit: Pioneer DEH-P9800BT
    Mids: Lanzar 6m
    Tweets: Crescendo CCX
    Fronts Amp: Alpine PDX4.100
    Sub Amp:Hifonics BRZ1.1700D
    Substage: 18" SSA ZCON
    Electrical: 160 Amp Alt, Duralast Gold, C&D270FR, 2/0 Throughout
  13. #12
    g6ryder's Avatar
    g6ryder is offline Supporting Vendor g6ryder is a Supporting Member of the forum!
    g6ryder is a Supporting Vendor of the forum!
    Jan 2011
    Claremore, OK
    1,113
    34 Post(s)
    I put a DAT2500.1 @ 1ohm to the pair of my VVX 10s daily they handled it fine never got stinky, Just be careful with your gain and stay clip free you should get away 1k maybe a little more a piece.
    Owner: Imperium Audio Designs
    Www.imperiumaudiodesigns.com
    Www.facebook.com/imperiumaudiodesigns
    Stephen@imperiumaudiodesigns.com
    www.instagram.com/imperiumaudiodesigns
    Audio Technix Dealer
    CT Sounds Dealer
    Imperium Audio Designs--"The power to command." Welcome to the movement!
  14. #13
    SourDeez's Avatar
    SourDeez is offline CarAudio.com Veteran
    Apr 2007
    Fuqy u
    4,134
    62 Post(s)
    Quote Originally Posted by UnderFire View Post
    And do you have proof that the BRZ does not do rated or are you just hating on hifonics like most?
    Headunit - Stock cassette player - Pioneer P9400
    Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
    Rear stage - Deleted (stolen) - Deleted
    Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
    Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
    Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
  15. #14
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,340
    134 Post(s)
    Give it more space 3.5 cubes
  16. #15
    g6ryder's Avatar
    Jan 2011
    Claremore, OK
    1,113
    34 Post(s)
    Quote Originally Posted by SourDeez View Post
    Likely he is stating that bc he hears it around, Ive owned the BRZ2400.1 and it was a very solid amp esp. for the price point although i never clamped it, it was very powerful and i loved it.
    CT Sounds Dealer
  1. Replies: 20
    Last Post: 05-14-2005, 02:46 PM
  2. Under-rated WRMS is it just bull
    By really****loud in forum Amplifiers
    Last Post: 07-21-2004, 03:01 PM
  3. Hifonics Amps Under rated/
    By Shyne151 in forum Amplifiers
    Last Post: 07-08-2004, 08:45 PM
  4. What's the most under-rated subwoofer?
    By Gauntlet in forum Subwoofers
    Last Post: 06-27-2004, 09:06 PM
  5. kicker amp under rated?
    By real_dvs in forum Amplifiers
    Last Post: 06-09-2003, 09:17 PM
