+ Reply to Thread
Results 1 to 2 of 2
Reload Thread: Help! I think i screwed up my amp!
    Ispeachy's Avatar
    Ispeachy is offline Junior Member
    Nov 2012
    BC, Canada
    I was replacing my amp with a different one. My previous amp had a metal ring on it that gets put on the screw that tightens a metal piece around the battery to keep it in place.
    So what happened was I put the ground cable in the slot of the power, and the power cable in the slot of the ground cable. The mix up was because my ground cable had a rubber protection on it and on it was written power cable. When I tried to connect that metal ring to the screw it sparked and startled me and it did that twice, then i connected it and my amp isn't on. There used to be a green light on the side and it doesnt turn on anymore! plz help! what happened?
    I also tried reconnecting my battery a few times but it didnt help.
    DaveVT's Avatar
    DaveVT is offline Like A Boss
    Apr 2002
    VT
    3,237
    6 Post(s)
    Re: Help! I think i screwed up my amp!
    check under hood fuse and amp fuses. If all are fine you probably blew something in the amp.
    http://www.caraudio.com/forums/subwoofers/538560-bass-tracks-%2A-frequencies%2A.html
    24 REFS- seth350,heatseeker,VOA_Nightmare,lude,Imaspaceguy9 0
    ,terryracing86x5,vic713,
    guy022077,Digital Mint,Netherland24,xnbastar,woody89,patalpine,
    foreman,mtdewelf,zeanimal2001,eatank,keifersracing ,86yota,arsonbob,
    JoeHemi57,MegaHurtz,t00p,echo42987
+ Reply to Thread
  1. Help! I think somethings wrong with my amp.
    By AATorres28 in forum Amplifiers
    Last Post: 09-30-2011, 07:39 PM
  2. HELP!!! New amp install screwing up my idle!
    By DeuceLee in forum Wiring, Electrical and Installation Help
    Last Post: 11-05-2007, 06:16 AM
  3. Would i screw up my amp if i....
    By 2002XLT in forum Amplifiers
    Last Post: 07-18-2007, 06:50 PM
  4. I think they screwed up my custom made enclosure
    By kingsxman in forum Enclosure Design & Construction Help
    Last Post: 04-19-2006, 07:39 AM
  5. Need help hooking up my amp.
    By RbAudio_Geek in forum Amplifiers
    Last Post: 08-18-2005, 02:16 PM
