+ Reply to Thread
Page 22 of 24 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LastLast
Results 316 to 330 of 357
Reload Thread: Need Help? Let Me know
  1. #316
    bigaudiofanatic's Avatar
    bigaudiofanatic is online now CarAudio.com Elite
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    Re: Need Help? Let Me know
    Wrapped
    First layer of resin
    ---------- Post added at 09:48 AM ---------- Previous post was at 09:47 AM ----------
    Will be installed a little later. I stuffed a little bit of poly fill to help keep vibration down. Keep in mind that I am by no means an expert and wrapping fabric!!! I know there is a bit of overlay behind the speaker.
    I help people with car audio, computers, and much more.
    AIM me at reimermatt
    http://www.caraudio.com/forum/showth...wpost&t=370497
  2. #317
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    Second battery added checking charging.
    Because there are two amps and fans, I decided to run a relay coming off the remote output of the MS8.
    Few pictures of the amps and powered on.
    ---------- Post added at 09:51 AM ---------- Previous post was at 09:50 AM ----------
    Beauty panel
    Wires are all organized.
  3. #318
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
  4. #319
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    This past weekend, I worked on a good friends jimmy. He completely blew his stock speakers. So I felt like I had to replace them.
    Installed
    Kenwood head unit
    Focal polyglass speakers
    metra axxess
    Future:
    infinity amp
    rear speakers
    Sub
    Lets get started
    Before
    During
    Wiring
  5. #320
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    I actually switched the tweeter mounting brackets. The left went to the right and right went to the left. This allowed the tweeters to be aimed just a tad of axis.
  6. #321
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    Today was a simple sub and amp integration into the factory system of a VW R32.
    Battery
    Fuse block ran and insulated.
    Used the 12 volt plug to wake up the LOC
    Powered the LOC from the fuse block
    Everything ran
    Set up
  7. #322
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    Subaru Legacy Rebuild
    Long story short, the customer contacted me about a year ago to correct what other shops had done. After fixing those issues the customer constantly changed either amps or speakers every month or so.
    So this is a complete gut and rebuild. Everything is being taken out and re ran or replaced.
    The amps will both be on a amp rack above the spare tire. The sub will now be centered in the trunk instead of to the side. Let's begin
    Tear down
    Found this when I was pulling up the power wire :o
    They spliced into the power wire for the MS8
    The goodies
  8. #323
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    Today I setup the tweeter pods, and did the first layer of resin.
    Made tweeter rings
    Glued into place
    First time doing the tweeter pods, so I did get some sag. Was not able to stretch it out.
  9. #324
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,671
    17 Post(s)
    he had that high of equipment and they took a chance on blowing it with such a ****** job?
    I am protesting Skar by giving them added exposure in my signature.
  10. #325
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    Quote Originally Posted by wenn_du_weinst View Post
    If you are talking about how the car came to me, you are correct it was shot work. If you are talking about my rebuild, I am not sure why you say that. As I said first time doing the a pillar tweeter pods. The sagging can be corrected.
  11. #326
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    New speakers installed
    Because the door panels have been taken off so many times; I replaced all the panel pins.
    Power wire and speaker wire ran
    Other pillar wrapped
  12. #327
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    Updated pics of the amp rack, aligned the amps and the holes. Going to be bolting them in with stainless steel bolts.
  13. #328
    jirehn's Avatar
    jirehn is offline Senior VIP Member
    Nov 2011
    Tempe, AZ
    369
    Thanks for this post dude, I will look forward to this offer, this is great.
  14. #329
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    Test fitted the amp rack in the trunk. Perfect fit!
    Now to start the false floor tomorrow and sub box.
  15. #330
    Nov 2008
    Bridgeton NJ
    24
    1,685
    2 Post(s)
    So today I got a lot done, most of the car is back together. Did get to test the woofers and sub however ran into a few problems including the sub box will not fit because of a seat belt in the way. So I will have to change the location to the left of the trunk and make a new beauty panel.
    Working on the sub box.
    All the old wires
    First layer of bondo
    Cut out
    All wires organized
+ Reply to Thread
  • You may not post replies
  • You may not edit your posts
