+ Reply to Thread
Page 21 of 26 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 301 to 315 of 388
Reload Thread: Need Help? Let Me know
  1. #301
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    Re: Need Help? Let Me know
    Wow nice work man!
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Kenwood DNX-692HD_____________ -Head Unit: Eclipse CD7100
    -Sub Stage: Focal KX40 16"_________________ -Sub Stage: Looking
    -Mids/Highs: Focal KRX & PHD AF____________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: Mosconi AS200.4_________________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: Mosconi AS200.4_________________ -Mid Amp: ^^^
  2. #302
    bigaudiofanatic's Avatar
    bigaudiofanatic is offline Dynamic Mobile Audio
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    I am in California read about it here
    California build thread
    I help people with car audio, computers, and much more.
    AIM me at reimermatt
    http://www.caraudio.com/forum/showth...wpost&t=370497
  3. #303
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Bump
  4. #304
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Today me and me new employee worked on a 2011 Nissan 370z. IT was COLD and it SNOWED but he stuck through it and learned a lot.
    Already hard at work! We both took a door and he mirrored what I did to the other one.
    Doors removed and starting to run new wiring.
    Learning to work in tight spots!
    Soldering is KEY!!
    Rest!
    SNOW!
    Tweeters installed
    Everything mounted and tested. Forgot pics of the head unit and speakers
  5. #305
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    I am currently working on a 3 day ISF full audio build.
    Products:
    JBL MS8
    Hertz 6.5 Coaxial rears
    Pioneer Stage 4 components running active
    2 Audison LRx amps and a alpine PDX M12
    2 Alpine Type R's
    2nd Battery
    I will break down the wiring diagram as best I can for future installers.
    Removing door panels
    Stock speakers vs aftermarket
  6. #306
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Good amount of depth
    Lines up with factory holes
    Rear doors
    Location behind the battery for 0 gauge
    Dyanamt trunk
    Amps
  7. #307
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Stock amp
    Speaker wires ran
    Inside door
    "I did not do the dynamat owner did"
    Factory wiring harnesses
  8. #308
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Solder and heat shrink connections
    Rubber tape to wrap them all nice
    Rear seats out
    Battery ground upgrade
    Factory mid location now home to tweeter. Not pretty but very strong. Gorilla epoxy
    Sub wiring
  9. #309
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Subs ready
    Most cables ran for tomorrow
    MS8 home
  10. #310
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Ok got the owner to send me the pics, have some more to come so please be patient!!!
    Trimmed the battery terminal cover to allow for the power wire to come out.
    Work in progress pics of the power wire wake up wire and so on.
    Organizing all the wires, zip tied every 6 inches or so. The two grommets towards the top of the rear seats provide great locations to run wires. NOTE make sure to cover them with some kind ot rubber rap and or shielding.
    Labeled all the outputs for the amps as for quick reference.
    Battery grounded, made sure there was no resistance for this ground.
    Amps installed on new rack
    Owner wanted easy access to his bass knob and radar
    Wiring up all the power wires!!
  11. #311
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Here are some finished pictures. Will get more when he comes for tuning. I will also check out if adding the sub to the inputs for summing adds anything.
    Fuse block was placed on top of the fuse box for a few reasons.
    Quick removal is you need to get to fuses.
    Held in place with no drilling any holes.
    Perfect location
    Also the ground wire was upgraded as well, using the stock grounding location only paint was removed and stock bolt.
    Subs installed
  12. #312
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Inbox cleared out
  13. #313
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Website is up
    bigAudioFanatic.com
  14. #314
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Bump for spring.
  15. #315
    Nov 2008
    Bridgeton NJ
    29
    1,934
    53 Post(s)
    Last year I worked on a members z and put the fallowing in:
    Kenwood 9980 head unit
    JBL MS8
    Hertz Mile speakers
    Hertz sub
    Audison 5.1K amp
    The owner wanted even more sound so I came back this week to do "stage 2"
    Added:
    Focal FPS 21160 amp
    Hertz Hi-Energy coaxial speakers"rears"
    Kinetick KHC140 battery
    Kicker 0 gauge battery
    Stinger fans
    Custom speaker pods
    Made the rings
    Pulled the carpet off the panels
    Started finding the right angle to mout the rings.
    Starting to epoxy the supports
    So far
+ Reply to Thread
  • You may not post replies
  • You may not edit your posts
