+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
Reload Thread: skar vvx 15inch DVC 2ohm
    TwoFosgate12's's Avatar
    TwoFosgate12's is offline Junior Member
    Oct 2016
    Lake county , CA
    26
    14 Post(s)
    Just got me a skar vvx 15incher DVC 2 ohm sub to replace my dual JBL s3 12inchers SVC, I gotta say the one Skar out performs those jbl s3's! louder bass and way better bass quality! also using the same amp I had powering the jbls a audiopipe 15001d apcl only difference is I have the skar on 4 ohms for know till I have broken it in and I have on moderate power level not cranked up at all so their is a lot of head room left with this skar I bet ill be flexing when I put that skar at 1 ohm!
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,186
    245 Post(s)
    7915 Post(s)
    Re: skar vvx 15inch DVC 2ohm
    to a certain point and thermal compression will kick in.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,729
    17
    30 Post(s)
    2685 Post(s)
    Quote Originally Posted by TwoFosgate12's View Post
    cool.. when u do wire to 1 ohm i'm sure it will be louder but make sure gain is low.. don't wanta melt that coil.. there is a method for setting gain close to the max rms power u want so hopefully u don't over power it to much.. i'd say set for 1k =31.6v at 1ohm here's video https://www.youtube.com/watch?v=gg2gl-fz2Qc
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
  4. Thanks TwoFosgate12's thanked for this post
    Likes TwoFosgate12's liked this post
  5. #4
    Oct 2016
    Lake county , CA
    26
    14 Post(s)
    would mounting it inverted help with that , help it cool more easily?
  6. #5
    Jan 2017
    NC
    6,729
    17
    30 Post(s)
    2685 Post(s)
    maybe but best reason to do that is it would give box more air space (if box is small) just make sure surround doesn't hit the sub cut out.. is it a ported box? also on the gain setting method AMP MUST BE ABLE TO DO 1K OR U WILL JUST BE CLIPPING IT.. so what amp and box do u have?
    2 ohms rule
  7. #6
    Oct 2016
    Lake county , CA
    26
    14 Post(s)
    the box is a pre fab it is a bit small in volume its a 2.6 cube and I should have a 4 cube volume also I am using a audiopipe 15001d apcl
  8. #7
    shredder2's Avatar
    shredder2 is online now CarAudio.com Elite
    Nov 2017
    Phoenix Az
    1,491
    41 Post(s)
    592 Post(s)
    2.6ft3 prefab on a VVX-15?.. Man that's SMALL, those subs in my experience dont do well till 4ft3 net or more... the amp will be enough but your box sux.
    Build the correct box for that sub tuned to your tastes and configured for your car and that amp/sub combo will do quite well.
  9. #8
    Jan 2017
    NC
    6,729
    17
    30 Post(s)
    2685 Post(s)
    yeah thats way small man, u woulda been better off with the 12 in that box..
    2 ohms rule
  10. #9
    Jan 2017
    NC
    6,729
    17
    30 Post(s)
    2685 Post(s)
    the ap 1500 does a legit 1260rms @1 ohm so u can set gain as i said anywhere like 30-31.9v or so DON'T USE BASS BOOST ON AMP OR HU (no loudness or preset eq) and don't turn hu past 80% volume (so if hu goes to 35 don't go past 28 and thats where u set the max volts like in video) keep power as clean as u can..
    2 ohms rule
  11. #10
    Jcsaudio's Avatar
    Jcsaudio is offline Senior VIP Member
    Sep 2017
    Worcester, MA
    394
    3 Post(s)
    177 Post(s)
    This subwoofer according to the reviews on Amazon seems to be a budget gem. I wonder if it is any good for a SQ sub? Im reading reviews from people who are comparing it to a JL W6 for whatever that is worth.
    2014 Sienna 2-way active SQ system. SB Acoustics SB29RDCN Tweeters. Focal PS165V mid woofers. Pioneer D9500F 75 watts RMS x 4. Pioneer BHS 5800 HU. AudioControl EQX. 10 Alpine SWS sub in custom ported box tuned to 35 hz on JBL GTX 500.
    2014 F-150 XL WT 2-way active budget SQ system. Tang Band 25-302SH 1" tweeters. Dayton Audio ND140-4 mid woofers. Pioneer D8604. JBL Club 5501. JL Audio Twk 88 DSP & FIX 86. Sundown SD3 10 sub ported/ 33Hz 1 cube.
    2014 CX5 3-way active SQ system. Pioneer 1330 NIX HU. Dayton AMT tweeters. Celestion AN2775 2-3/4 midrange. NVX XSP65 mid woofers. Pioneer PRS D4200F 75 WPC x 4. Infinity K1000. JL Audio Twk 88 DSP. Sundown SA 12 2 cube/33Hz.
  12. #11
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    Quote Originally Posted by BOOMINGRANDPA View Post
    Coming up huh gramps?
  13. #12
    Jan 2017
    NC
    6,729
    17
    30 Post(s)
    2685 Post(s)
    Quote Originally Posted by Jcsaudio View Post
    This subwoofer according to the reviews on Amazon seems to be a budget gem. I wonder if it is any good for a SQ sub? I’m reading reviews from people who are comparing it to a JL W6 for whatever that is worth.
    they ok sub especially for the $ but not an sq sub.. box has alot to do with sq though, so a nice sq sub can sound worse than yours in a bad box.. the skars from vvx up are modeled after if no straight copy of sundowns, look at ddx basically same as sa but peeps agree sundown is better, probably cheaper coils in skar..
    2 ohms rule
  14. #13
    Jan 2017
    NC
    6,729
    17
    30 Post(s)
    2685 Post(s)
    Quote Originally Posted by Papermaker85 View Post
    huh
    2 ohms rule
  15. #14
    Oct 2016
    Lake county , CA
    26
    14 Post(s)
    I know I had ordered it from onlinecarstereo.com and they had it advertised at a different volume then it actually is kinda pissed me off but I just said **** it! I'm going to get a different box soon! I just found another ground shaker box at 3.77 cubes so says the actual ground-shaker.com website I then checked the same box on onlinecarstero.com and they have the volume wrong again lol this kinda frustrates me don't know who to trust here and Im no good at charpentry and fabrication! ill keep looking though!
  16. #15
    Jan 2017
    NC
    6,729
    17
    30 Post(s)
    2685 Post(s)
    there are no good prefab boxes most are to small all are tuned to high (i've done the math on tons of them).. i found 1 seller makes good boxes (like mine, i'll put pic in avatar) i got it without carpet or terminal designed it way i wanted and had it in 4 days (cause the cut wood with machine, not just saw so faster) but good boxes are not cheap.. i'll see what they have in 15" if i see one looks ok i'll show u link., other than that u should get 1 made if u can find someone to make one shredder is good at designing boxes (and he did like 150db with 2 skar 12's)
    2 ohms rule
+ Reply to Thread
