Results 1 to 15 of 15
Reload Thread: Brahma HT
    IamDeMan's Avatar
    IamDeMan is offline Banned
    Nov 2004
    /dev/null
    38
    22,310
    Brahma HT
    I plan on making a HT sub using a 15" Brahma D2. I will be wiring the VC's in series for a 4ohm load. I want this sub to be best suited for movies, period! For now it will be powered by a sony 250 watt plate amp, but I will replace it down the road with a 500 watt plate. I have never designed or built a home sub enclosure and wanted oppinions on the type of box and size and tuning of it. Any recomendation/suggestions are aprreciated.
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,691
    Re: Brahma HT
    Your Brahma will work very well off low power in the HT environment, just a few things to keep in mind.
    A larger sealed or ported enclosure will allow you to increase efficiency - it will also increase low end response. I would go with a low tuned ported box, tuned around 22-25Hz, and build it on the larger side of the recommended (talk to Adire or a member on here that designs boxes about enclosure specs).
    IamDeMan's Avatar
    Nov 2004
    /dev/null
    38
    22,310
    Re: Brahma HT
    Quote Originally Posted by Jack Frost
    So do you think I would even have a need for or see a benefit from using a 500 watt plate amp? If so then I would just stick with this 250 watt SONY plate.
    I was thinking a large low tuned vented enclosure would be in order. Similiar to what some people do with Shivas and Sonotube(at least in terms of volume and tuning). When I played with WinISD it showed a 9CUft enclosure tuned at 19hz to be the optimum in its thinking. I have read enough here to see that the program can't be trusted entirely though. This is why I was looking for input from people with real world experience on this sub. I may see if someone wants to work out the plans for this beast.
    Thanks for the reponse.
    EDIT: I also meant to ask if this sub is well suited to be a downfiring sub?
    PV Audio's Avatar
    PV Audio is offline The Vision of Sound
    Apr 2004
    Indy
    24
    19,672
    Re: Brahma HT
    i would advise against downfiring the brahma, but i've never done it so it may surprise you. i would still upgrade to the 500 watt amp as you may want to continue onto greater things in the future.
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,691
    Re: Brahma HT
    Downfire it if you want...see no reason not to.
    ToyTundra's Avatar
    ToyTundra is offline has a slanted soundstage
    Jan 2005
    AZ
    940
    Re: Brahma HT
    using this:
    http://www.adireaudio.com/Files/Tech...rientation.pdf
    A Brahma 15 MKII is acceptable for downfiring. Sag=.367mm; xmax=29mm
    So sag is only 1.27% of Xmax which is good (should be less than 5%)
    IamDeMan's Avatar
    Nov 2004
    /dev/null
    38
    22,310
    Re: Brahma HT
    Thanks for the explanation. I knew there was some way of telling whether a driver was acceptable for downfiring or not, just didn't know exactly how to tell. This is great info.
    vettelovr1124's Avatar
    vettelovr1124 is offline Livin' Life
    Oct 2002
    Memphis Area/ B'Burg
    26
    1,056
    Re: Brahma HT
    I suggest you go infinate baffle.
    Really, though...low-tuned ported with liberal amounts of volume, and go for the 500W amp...just in case.
    Hokie, Hokie, Hokie, Hi.
  9. #9
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,691
    Re: Brahma HT
    Sonotube ported enclosures are so cheap it's not funny...get a Sonotube, a piece of PVC pipe, and you're good to go. All you need to fabricate are some end caps and feet.
  10. #10
    Diplexers's Avatar
    Diplexers is offline Logarithmic Robot
    Dec 2003
    Phoenix, AZ
    36
    2,430
    Re: Brahma HT
    I prefer Crown, or QSC. I built an auditorium system with Crown 500's.(I think) it been about 8 years ago. They were pushing the Dual 15" JBL Pro Audio woofers. The depth was so amazing. Tuned way low, however; there was a lot more room displacement. I am rambling, goodbye.
    Eclipse CD5000
    PPI... DEQ-230
    PPI... PC450 4 channel
    Eclipse 3640 4 channel
    FI 12"BTL
    Eclipse DA7232 (2000 watts RMS)<------
    Kicker ND 25 Tweets
    Kicker RS6 6.5" comps
    Kicker R5c 5.25" midrange
  11. #11
    myvanpounds's Avatar
    myvanpounds is offline I dont own a van any more
    Oct 2002
    Cincinnati, OH
    28
    759
    Re: Brahma HT
    *cough*t-line*cough*
    2005 F150 XLT Supercab. 5.4L 3.73
    HU: Kenwood DDX-7015
    Sub amps: 2x autotek xs900.2's
    Midbass amp: autotek xs550.2
    Front stage amp: audison LRx 2.250 - FOR SALE
    Midbass: 2x eD 7Kv.2 (RIP lonny)
    Components:Phoenix Gold Rsd 6.5's - FOR SALE
    Electrical: Optima, Knukonceptz, Streetwires
    Subs: 4x eD 9Kv.2's
  12. #12
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,691
    Re: Brahma HT
    No, no...come back! Who said you could take your knowledge and leave?
    Agreed.
  13. #13
    Dec 2002
    Canada, Calgary
    29
    117
    Re: Brahma HT
    I agree with the pro amp idea. Has worked for me, just make sure to have a crossover handy or in my case built right in.
    Steve
    New vehicle!!!!!!!!!!!!
    1981 K5 Blazer silverado edition.
    v8 350
    Black Jack headers
    four barrel carb
    New Duramax exhaust system
    Stereo...
    Panasonic cq-c7301u
    Alpine type R 6x9's
    Crossfire bmf 1000d
    Crystal cmpx2 12".
  14. #14
    jlaine's Avatar
    jlaine is offline Vaporware
    Apr 2002
    Morris, MN
    2,607
    Re: Brahma HT
    Quote Originally Posted by IamDeMan
    What kind of space?
    Feeling insane? 300L tuned to 16Hz should feed that insanity.
    250 watts will be plenty sufficient.
  15. #15
    kotec123's Avatar
    kotec123 is offline Flame
    Sep 2005
    Chicago
    3,027
    Re: Brahma HT
    throw some kicker 2500.1 strapped at that brahma and watch the magic happen!
  1. IDMAX or Brahma 12....
    By Gauntlet in forum Subwoofers
    Last Post: 06-19-2005, 03:16 AM
  2. Re8 Ht
    By abcheng in forum Subwoofers
    Last Post: 03-05-2005, 11:03 PM
  3. Brahma vs. idMAX
    By noob with an RS in forum Subwoofers
    Last Post: 02-28-2005, 02:27 PM
  4. JL 12w7 vs Brahma 15
    By Bumpin03 in forum Subwoofers
    Last Post: 07-11-2002, 11:23 PM
