ok, after looking around for awhile i have come to like this setup.
2- http://www.ascendantaudio.com/Atlas%2015.htm
and - http://www.partsexpress.com/pe/showd...number=300-806
but I don't know if I should go ported or leave it sealed, i believe i read some were to that you can use these subs in home use. Also in home audio is it better to have a high qts or a low qts, what are the pros cons.
explain this a little please http://www.ascendantaudio.com/Atlas%...d%20wiring.htm .
I am guessing the best way to tell if a sub can be used in a down firing application is to call but is their any way to look ate the specs and tell if it is ok.
Register To Reply
, preferably tables that dont shake like mad
Bookmarks
