+ Reply to Thread
Results 1 to 5 of 5
Reload Thread: Basic home stereo questions
    Turnt Audio's Avatar
    Turnt Audio is offline Member
    Feb 2011
    San Diego
    51
    8 Post(s)
    Looking for a solid home stereo setup, on somewhat of a budget, using 2-4 indoor/outdoor speakers and most likely the ability to add a subwoofer. Been looking at this receiver: https://www.crutchfield.com/p_022RS2...ha-R-S202.html
    to go with maybe these speakers: https://www.amazon.com/dp/B0001VHARE...4MWXAM0J&psc=1
    or maybe Kicker kb6000 speakers (https://www.amazon.com/dp/B0051BS28A...4MWXAM0J&psc=0)
    Can a subwoofer be used with that Yamaha receiver? If so, would I be able to use 4 speakers with a sub, or just 2 speakers?
    It says that receiver sends 100 watts X 2 ...is that the max watts rating? I know how the rms/max power ratings work for car audio, but what does it mean for this home stereo? Would each speaker be getting 50 watts RMS? Would it still be 50 watts RMS when using 4 speakers? I believe those Yamaha speakers say they handle 120 watts MAX...what is the RMS rating?
    Basically I'm looking for the best bang for the buck possible with sound quality and loudness...I want some watts being put into my 2 or 4 speakers! Already have plenty of speaker wire.
    poolman966554's Avatar
    poolman966554 is offline Senior VIP Member
    Mar 2015
    NW, PA
    397
    1 Post(s)
    181 Post(s)
    Re: Basic home stereo questions
    It says on the back of the reciever you posted 8 ohm min.. I didnt see a ohm rating on the kicker, and the others are rated at 6ohm. I personally wouldnt wired low on a home theater amp.
    Avinusa HU for 2007 Honda Crv
    Electrical : Duracell Grp 34 AGM with Big3
    front stage : Sundown Sae 50.4 on DB651s
    Sub amp : AB 4480.1
    Subs : 2) Sundown SA-12s @1 ohm in 3.8cu'ft @ 32hz
    Feb 2011
    San Diego
    51
    8 Post(s)
    Should the ohm rating on the receiver match the rating on each speaker? What kind of receiver (amp?) and speakers should I go with, if my goal is just to get very good, clean sound and lots of volume (at least 50 watts RMS per speaker?), for under $350? Maybe a couple examples of which products I should pair together to do it right and get the best outcome?
    Maybe outdoor speakers aren't the best option for me? I chose that kind of speaker for the different mounting options, and I will probably have an "outdoor" use for them in the future. I just want a nice, yet affordable home sound system, to connect phone/computer/ipod/TV into. The very best bang for the buck for a system under $350, preferably using 2-4 outdoor/indoor speakers with option of adding a sub in the future.
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,116
    244 Post(s)
    7873 Post(s)
    Quote Originally Posted by poolman966554 View Post
    I wire mines to 4 ohms Zero issues over 3 years already. The power supplies handle it as long as you keep the receiver ventilated.
    Quote Originally Posted by Turnt Audio View Post
    RMS is useless, dont even bother buy speakers based on that. Buy it based on sensitivity levels along with frequency response and overall educated review/feedback of the speaker aka from people comparing the speaker to much higher end speakers that actually knows what they are talking about with an in depth sound review along with their room setup/positioning, staging and imaging. Ignore the typical noob that says "this speaker is great!! loud and clear!!!"". Also if its inside the house, BUY HOME THEATER SPEAKERS. outdoor speakers s*uck
    Also spend a bit more on a 5.1 reciever with better DAC please. You are asking for trouble when you want a single 2.1 reciever powering 4 speakers.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    JohnKuthe's Avatar
    JohnKuthe is offline CarAudio.com Veteran
    Sep 2016
    Missouri
    2,074
    13 Post(s)
    1206 Post(s)
    The receiver has only 4 speaker output for it's speaker A and speaker B. You'd have to give up a second set of speakers if you wanted to drive subs off the mail speaker outputs. Better to run a second sub amp and use the tape output to drive it from the receiver.
    Means it will get a decent set of speakers pretty loud! If you put that into my Klipsch La Scalas you could just about blow up the house! But the La Scalas are like 110dB efficiency or better!
    Oh, and BTW the RMS rating is the Root Mean Square rating, a way of approximating an alternating current's wave "amplitude".
    Go with a second power amp for your subs and if you REALLY want to run also a second set of speakers get RCA male to male splitters and split the Receiver's tape OUTPUT to it and if you wish any tape machine you may use too! It;s a line level outpiut and will certainly drive two lione level loads at once! Mine always have.
    John Kuthe...
    2006 Grand Caravan "Baby II"
    Alpine CDE-153BT HU
    Alpine PXA-H800 DSP
    Alpine PDX-V9 main amp
    Alpine PDR-V75 secondary amp
    4 Alpine SPR-69 6x9" midrange
    2 PHD 5.1 AF 5.25" drivers w/ separate tweeters and passive crossovers with plans of going full active!
    JL Audio 12TW3-D4 400W TW3 Thin-Line Series 12" Dual 4 ohm Subwoofer set to 2 Ohms
    Damplifier Pro, BQuiet and Luxury Liner Pro sound deadening, lots!
+ Reply to Thread
