Results 1 to 4 of 4
Reload Thread: Budget 5.1
    Sep 2012
    Wilmington
    99
    28 Post(s)
    Budget 5.1
    For a budget home reciever is there a top pic or are they similar? Thinking Sony, Pioneer, Onkyo. $150 to $250
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,044
    109 Post(s)
    7728 Post(s)
    Re: Budget 5.1
    McIntosh. But really, whatever does what you want within budget. Speaker placement is more important.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
    Zero_Ohms's Avatar
    Zero_Ohms is offline Member
    Jun 2016
    Mosinee,WI
    61
    27 Post(s)
    Re: Budget 5.1
    Can't go wrong with Yamaha. Onkyo makes good stuff too. A lot of the newer stuff has cool stuff like airplay and Bluetooth and even apps for your phone to control the receiver.
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,974
    241 Post(s)
    7794 Post(s)
    Re: Budget 5.1
    Id shoot for an onkyo tx nr646 refurbished off accessories 4less. Dual 32 bit dacs dolby atmos, all modern features, good eq, a lot of clean power, the works. No other reciever comes close in the price range. All in the 350 and under only use either single 32 bit dac and most use 24 bit dacs and arent capable of high end audio processing. Giant fking leap against any other reciever i tried in the 250 range. Nothing even came close to half as good sounding as the nr646.
    Its 1000% worth the extra dollars. Mines costed 280, prices change from time to time so just wait out.
    https://youtu.be/93CshEFfue4
    This is at 1/4 the way up recorded on a ****** phone mic.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
