Results 1 to 6 of 6
Reload Thread: New towers. Final impedance questions??
    havoc97's Avatar
    havoc97 is offline Member
    Feb 2007
    MINNESOTA
    80
    2 Post(s)
    Building a new set of towers currently and have a few questions I can't seem to figure out about the impedance after the crossover.
    Here is the setup:
    ID CD1E Horns (4 ohms)
    Focal 6.5 Mids (4 ohms)
    Tang band w6-1139sg subs (4 ohms)
    (Odd selection of equipment, but had it laying around and figured might as well use it up)
    I was thinking of running a three way passive xover, and running a behringer A500 amplifier with these specs:
    Output power (RMS, 1 kHz @ 1% THD): Stereo mode (both channels driven): 125 watts RMS x 2 @ 8 ohms, 185 watts RMS x 2 @ 4 ohms; Bridged mono: 375 watts RMS x 1 @ 8 ohms Output power (peak power, 1 kHz): Stereo mode (both channels driven): 175 watts x 2 @ 8 ohms, 300 watts x 2 @ 4 ohms; Bridged mono: 600 watts x 1 @ 8 ohms Weight: 18.5 lbs. Dimensions: 4" H x 19" W x 10.85" D.
    Question is, what will my final impedance that the amplifier sees once those speakers pass thru the crossover?
    From what I understand the amp will see 4 ohms for each frequency range, but I'm not sure if that is right.
    Here is a tower preview pic
    duanebro's Avatar
    duanebro is offline CarAudio.com Elite
    Oct 2011
    Grand Blanc, MI
    561
    74 Post(s)
    Re: New towers. Final impedance questions??
    it depends on the xo. You could have a short depending in the xo you build. (not likely, but it could happen.) You will most likely end up around 4 ohms. How are you designing the xo?
    HU - Pioneer
    Front Stage - Old school MB Quartz run off a JL e2150
    Rear Stage - Stock - well one works, LOL
    Sub - Tang Band 740C in between the front seats
    Sub Amp - A tiny Kenwood. - because it fits under the seat.
    Total Spent on everything $50.
    havoc97's Avatar
    Feb 2007
    MINNESOTA
    80
    2 Post(s)
    honestly i was planning on using on of the dayton audio xo's off parts express. Havent ever designed/built a xo so wouldnt know where to start.
    Plan on using a 500/4000hz 3 way.
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,633
    1275 Post(s)
    using a prebuilt xover is like using a prefab enclosure.
    You really need to have one designed properly for it to work well.
    I am protesting Skar by giving them added exposure in my signature.
  5. Likes duanebro liked this post
  6. #5
    duanebro's Avatar
    Oct 2011
    Grand Blanc, MI
    561
    74 Post(s)
    Quote Originally Posted by havoc97 View Post
    Here is the setup:
    If I am looking at this right you are planning on using the horn on its side? you do know that horns have a controlled output pattern. So you will have to aim them right at you to hear them and they will reflect off the floor and ceiling. I really think you should rethink your design. Also what is your frequency response of the drivers? what is the efficiency for the drivers?
    HU - Pioneer
  7. #6
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Quote Originally Posted by duanebro View Post
    i saw the same thing. cant do that. buy a new waveguide from parts express that gives a 60x40 dispersion. 60deg is is horizontal or a spherical. note that the horn waveguide determines the lower frequency range for which the horn is controlling dispersion.
    premade crossovers can work, but you don't want to use them. you want the mid to play a wider range, like 200Hz - 4kHz
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  1. Installing new deck - Power wire question
    By thecheesypoofs in forum Wiring, Electrical and Installation Help
    Last Post: 07-04-2002, 02:50 AM
  2. New to Forums, Many Questions
    By AkumaSG in forum General Discussion
    Last Post: 06-22-2002, 12:24 PM
  3. new sub box---sealing question
    By audiotaylor in forum Subwoofers
    Last Post: 04-30-2002, 11:48 AM
  4. Pics of my NEW and final ABC box....
    By Tryin2bump in forum Wiring, Electrical and Installation Help
    Last Post: 01-23-2002, 06:24 PM
  5. Pics of my new and FINAL ABC BOX...
    By Tryin2bump in forum General Discussion
    Last Post: 01-20-2002, 12:09 PM
