Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 53
Reload Thread: Another NS3 Build: Funky 2-Way
  1. #16
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    33
    15,426
    21
    Re: Another NS3 Build: Funky 2-Way
    lookin snazzy!!!
    cant wait to see how you finish them!
  2. #17
    hempy's Avatar
    hempy is offline bass wiener
    Nov 2006
    nola
    32
    700
    Well after I noticed that the inside layers of the second cabinet weren't lining up, I taped them all together and ran them on the router again.
    Then i used a 3/4" square poplar dowel to make blocks for the screws to go in through the back panel. I ran them on the router to match the inside countour.
    And cut them into 1" blocks.
    The original layout, which would eventually get changed.
    I ran the blocks on the router with a sanding drum, just to clean them up a bit.
    And clamped them in
    Once I was done with that, I glued the baffles on each speaker. I had to be cautious not to mess up that clean edge around the woofers.
  3. #18
    hempy's Avatar
    Nov 2006
    nola
    32
    700
    In lieu of an actual drill press, I ghettorigged drill bits with tape so they could fit in the router. I clamped the base to the workpiece and use the plunge base as my drill press. I had to get perfectly straight holes for the mounting screws.
    I countersank each hole about 5/16" to accommodate some oversized stainless screws.
    Complete with burgerlighter.
  4. #19
    hempy's Avatar
    Nov 2006
    nola
    32
    700
    I think I may have figured out how I'm going to do the mounting bracket. I've been pricing ones out, and I'm not really too excited about paying out the *** for good wall mounts.
    I started out looking in the cabinet harware, but nothig really caught my eye. But when I went by the metal stock, I noticed the threaded rod and got an idea.
    I got a short 3/8" piece and used a vice, a big *** socket, and a rubber mallet to bend it into the shape I wanted. I'm not sure if I'll stick with carriage bolts or just use threaded rod, but I think I'm going to use two pieces for each speaker, centered behind the woofers, which leaves the area behind the tweeter free for binding posts.
  5. #20
    hempy's Avatar
    Nov 2006
    nola
    32
    700
    I found exactly what I wanted while browsing around at Home Depot. I found stainless threaded rod, and although it was pretty expensive ($8/3ft) , it was exactly the kind of thing I was looking for.
    Someone suggested that I use the rods themselves for my binding posts, which I think I'm definitely going to do.
    I'm trying to find some stainless steel fender washers, but the ones at Lowes are in packs of 5 and cost like $5. I'm going to try and find some singles somewhere. I plan on getting a 5/26" washer for the 3/8" rod, then drill the center out a bit and thread the washer, so I can thread it onto the rod and have it welded, instead of having a washer and nut on the back of the speaker.
    I think I'm going to make the wall plate out of MDF or something, as it's what I have laying around. I was going to originally go with some steel or aluminum plates for the wall, but if I'm going to use them for conductors I need them isolated.
  6. #21
    96MaxGLE's Avatar
    96MaxGLE is offline CarAudio.com Veteran
    Apr 2005
    Greenville, NC
    36
    2,292
    looking awesome...
    Refs: f150john, Cutdawg84, Louisiana CRX, RJ 22, TeamPSI, ace_800, 2002XLT, dragnix, hoss, casper97ta, CrossFired, foreman, Bassballin, lilmaniac2, pickup1, 350bangin, Blunt, its_bacon12, revrider1, 2kchevy, rcnshoe, Brian Owens, Showrides, Stevew007, Belunt, Z71999, Dozy_production, Impalafan95, Snova31, Surgical
  7. #22
    hempy's Avatar
    Nov 2006
    nola
    32
    700
    I bought some cheaper regular steel threaded rod to get right before bending the stainless. The first one I bent came out pretty well, although my method of bending was pretty crude... beating it with a rubber mallet while in a vice next to a big socket. The second I put in and tried to bend broke, I tried again a few inches up and it broke again. So, I went and got more rods, and picked up some pipes to slide over the rod whie bending.
    I then decided to make a bending jig for it, and just bend with the pipe. I routed holes for the bits to sit in, and the whole thing is bolted together using the broken threaded rods. I put that whole thing in the vice and bent it, resulting in a much nicer looking radius, and no marring from the hammering or the vice.
    I think I will be able to use just the washers on the rod without welding, which would be expensive and may screw up the finish. I used 5/16" fender washers and threaded them, so they hold when bolted from behind. The washers will be flush with the surface on the speakers and wall plates.
    I think I will still rebend the top bar, as the one bent with the jig has much smoother bends, and I'd like them to match when starting with the stainless steel.
  8. #23
    hempy's Avatar
    Nov 2006
    nola
    32
    700
    I routed out recesses for the stainless washers and used the clamps to force them in, as I left them tight. It looks and feels really good.
    I also finally figured out how I'm going to get all four rods bent correctly. I"m going to make all four with identical bends, then simply bolt it together, and torque with clamps until it is in the right position.
  9. #24
    req's Avatar
    req
    Jul 2004
    Syracuse, NY
    33
    15,426
    21
    ingenious. maybe put some heat-shrink tubing on the rods when you are all done for a nice matte black look.
    awesome so far! make me a set of 5 for surround sound lol.
  10. #25
    Alpineforever's Avatar
    Alpineforever is offline CarAudio.com Elite
    Feb 2008
    Austin TX
    28
    672
    1 Post(s)
    thats ****ing awesome man... i want to be you when I'm older
  11. #26
    hempy's Avatar
    Nov 2006
    nola
    32
    700
    Quote Originally Posted by req View Post
    If it's worth it, I'm down. I'd love to do this **** for money.
  12. #27
    hempy's Avatar
    Nov 2006
    nola
    32
    700
  13. #28
    hempy's Avatar
    Nov 2006
    nola
    32
    700
  14. #29
    schrummy's Avatar
    schrummy is offline CarAudio.com Elite
    Jun 2008
    Ames, Iowa
    1,381
    8 Post(s)
    nice work...
    Team TREO
    Team Midwest
    Team Gorilla
    USACI- trunk 0-1000 156.4 and climbing
    153 sealed on the dash
    yes its a trunk car and yes its only (2) 12s...
    refs=sold to......R/T Pimp, mustangowner, zyklonb, Miles0803
    Bought from…..2002XLT, R/T Pimp, 92c1v1c, Miles0803, camshoc, dbeez, goindef154
  15. #30
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    10,782
    6 Post(s)
    1266 Post(s)
    VERY nice craftsmanship. Only potential issue I see is the very tightly press fit washers. Assuming you plan to prime/paint then the fit will get MUCH tighter and possibly chip the paint trying to reinstall them. Would hate to see you run into issues with the finish after all that hard work...
