Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 49
Reload Thread: Silver Flute/Peerless, Home Audio Build
  1. #16
    joetama's Avatar
    joetama is offline The British Ear
    Nov 2005
    Cincinnati, Ohio
    32
    15,306
    Re: Silver Flute/Peerless, Home Audio Build
    Waiting to see more!
  2. #17
    Thieroff's Avatar
    Thieroff is offline The Master of Meatcutters
    Apr 2006
    Pittsburgh Pa
    2,710
    Haha, me too, I'm going to purchase birch tonite.
    I should have my cuts done saturday night, I may possibly start on the xovers in the next day or so.
    So I will definately have more pics ASAP
    CT
    Pioneer880prs
    TC Sounds DB-500s
    PG Tantrum 600.4/PG Tantrum 1200.1
    CDT HDs
    Sold to :
    Vosschs, HiAmplidude, vipervin, KojiroTakenashi, BassAddictJ, SkyDeaner, Mattmcss, MaxSEma, Tapout, Playboyclic, ls2poweredgoat, amedeuce
    Traded to:
    Flaus, Lckmyblls, audiobahnuser18
    Bought from:
    FF92, Lckmyblls, DjDillioDon, Pjvoc, Mattmcss, Kasimo420,CBFryman2, BBB543, allenzo
  3. #18
    thadman's Avatar
    thadman is offline CarAudio.com Elite
    May 2005
    Indiana
    1,514
    What behooved you to purchase the drivers you did?
    Why an 8 paired to a 25mm dome tweeter?
    I have a hard time believing you'll have a homogeneous transition between the tweeter and the midrange, you'd be exploiting each's weakness. The Peerless is going to struggle greatly below 3khz im guessing, and with the Seas 27TBFCG (phenomenal performer that performs equally as incredible as its MUCH more expensive brother) being a few dollars more why did you choose it?
    The silver flute specifically arent known to be very renowned performers...why not a smaller driver or a better engineered driver? I havent read any reviews on the specific driver you're using, but I have read some reviews on its smaller brother, the W14 (~5.5). It was specifically recommended to be used <1800hz as its top end response wasnt quite so favorable...with that being said I believe that specific 8 is going to be plagued by odd-order harmonics (the offensive kind). I would do some free-air testing or find some frequency response tests...if you want good reproduction it is going to have to be clean past ~8000hz as the 3rd harmonic of this frequency is going to excite where you plan on crossing.
    Why not the Dayton RS225 (if you REQUIRE a low-cost 8, although most drivers of this diameter are incredibly undesirable for the upper midrange and lower treble) and RS28A/Seas 27TBFCG?
    It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong. - Richard Feynman
  4. #19
    thadman's Avatar
    May 2005
    Indiana
    1,514
    I found some data sheets on that Silver Flute and it appears to have a NASTY breakup occuring between 4-5khz and manifests itself sharply from 2khz upward. If you DO intend on using this driver, I would highly recommend on using an extremely high order filter around 1000hz maybe 1100hz. Otherwise you're going to have a very offensive passband (lots of odd order harmonics) in the area where the human ear is most sensitive...big no no.
  5. #20
    Thieroff's Avatar
    Apr 2006
    Pittsburgh Pa
    2,710
    Quote Originally Posted by thadman View Post
    Well, this set is being designed as a prototype, and it is really just a low cost experiment.
    I believe the Peerless should fare just fine around 2.5khz, on a 4th order slope. These tweeters were actually given to me a while back by another forum member and I wanted to put them to use. They have a relatively low Fs (1050hz) and one would assume that they will work just fine.
    Why an 8" midrange?
    The FR graphs genuinely don't look that bad, and like I said this is designed to be a low cost setup. With a 2nd order network I believe -12db at 5khz will be sufficient enough.
    Do I currently know what it is going to sound like?
    No, all I can go on is what information the graphs have given me, and my fiddling with crossover software.
    Have I had any past experience with Silver Flute products?
    No, although in my free air experiences with this driver it does not come out harsh, nor muddy. It is a laid back, natural sound driver.
    Do I still plan on building this set?
    Absolutely.
    Thadman, thank you for your input on my build project. I will hold all of your information into consideration once enclosure testing goes underway.
    CT
    Pioneer880prs
    TC Sounds DB-500s
    CDT HDs
    Sold to :
    Traded to:
    Bought from:
  6. #21
    Thieroff's Avatar
    Apr 2006
    Pittsburgh Pa
    2,710
    New pics
    Stain
    Polyurethane
    Foam Brushes
    Right angle clamps
    Birch Ply
    Sandpaper/sanding blocks
    Plus the drivers
    CT
    Pioneer880prs
    TC Sounds DB-500s
    CDT HDs
    Sold to :
    Traded to:
    Bought from:
  7. #22
    Beat_Dominator's Avatar
    Beat_Dominator is offline Yea, thats Mecha Godzilla
    Mar 2005
    Phoenix Arizona
    35
    21,990
    6 Post(s)
    Learn by expiramentation
    Comming Spring 2009
    I make rear-loaded, double crabshell, isobaric enclosures.
  8. #23
    joetama's Avatar
    Nov 2005
    Cincinnati, Ohio
    32
    15,306
    Quote Originally Posted by Beat_Dominator View Post
    Learn by expiramentation :thumpsup:
    I think he should be fine. This is a very good learning project. I give him the thumbs up!
  9. #24
    thadman's Avatar
    May 2005
    Indiana
    1,514
    You are misguided if you believe your 8 is going to cross that high without *****ing...a LOT of it mind you lol
    You can get an idea about how a driver is going to perform distortion wise by observing its frequency response. At 3-5khz we have a large peak, we will have high levels of 2nd order harmonic distortion between 1500 and 2500hz. We will also have high levels of (offensive) 3rd order harmonic distortion between 1000 and 1667hz as the 2nd and 3rd harmonics are multiples of the original peak. See my point? Crossing that high is a really bad idea.
  10. #25
    Thieroff's Avatar
    Apr 2006
    Pittsburgh Pa
    2,710
    Quote Originally Posted by B&W_EE View Post
    Word up, thanks man
    Well, currently I have the design plans all together, and the parts on hand.
    I'm going to give it a shot.
    If all else fails it's back to square one. I believe experimentation will breed knowledge.
    I'm not disregarding your thoughts in any way shape or form, just so you know.
    I'm one of those guys who has to hit his head off of a brick wall a thousand times to figure out that's not the way to do things.
    CT
    Pioneer880prs
    TC Sounds DB-500s
    CDT HDs
    Sold to :
    Traded to:
    Bought from:
  11. #26
    thylantyr's Avatar
    thylantyr is offline CarAudio.com Elite
    Apr 2005
    [Yoda] Belong to us all your base are...
    1,395
    W20RC38 - Wool-filled Paper Cone Woofer
    http://www.madisound.com/silverflute.html
    If the woofer you have is untreated paper cone, then read below.
    Here's a tip. Some of the best sounding midranges are paper treated cones.
    Non treated paper they can have sonic issues at the higher frequencies.
    You can use the lacquer cone treatment mod on that woofer to tame the higher
    frequency nasties, it should sound pretty sweet.
    Get a $5 spray can of lacquer, clear type. Example;
    http://www.builderdepot.com/RUSTOLEU...mg/6021257.jpg
    Get an empty soda can like so;
    http://moon.ouhsc.edu/dthompso/namic...s/coke_can.gif
    Get a 1" cheap paint brush like so;
    http://www.impactdecor.com/acatalog/brush_syn_25mm.jpg
    Cut the empty soda can in half.
    Rinse and dry the can.
    Spray some lacquer in the soda can.
    Dip the paint brush in lacquer and apply a thin coat to the woofer cone, dust
    cap, but not the surround.
    Let dry. Repeat about 4 to 6 times to build up.
    The spray can lacquer is ideal because it's not thick like the non-spray type,
    this allows it to soak in the paper fiber. Lacquer coats meld with previous coats
    to form a thick coat.
    This will add mass the woofer, lower Fs, tame high frequency nasties, and you
    loose a little bit of sensitivity. The paper is now protected against the environment and will last forever vs.
    drying out and getting brittle over time. The SQ should improve.
    Try this out.
    Do two coats. Listen to the woofer full range, free air. Compare the sound to the unmodded woofer.
    If you think there is progress, then do two - four more coats until you think it's good. The full range sound
    test will tell alot, trust your ears.
  12. #27
    Thieroff's Avatar
    Apr 2006
    Pittsburgh Pa
    2,710
    Quote Originally Posted by thylantyr View Post
    Try this out.
    Thylantyr,
    Thank you, the cone is actually made of wool on the particular driver I'm using.
    That is a very good read though
    CT
    Pioneer880prs
    TC Sounds DB-500s
    CDT HDs
    Sold to :
    Traded to:
    Bought from:
  13. #28
    thylantyr's Avatar
    Apr 2005
    1,395
    made of wool
    If it absorbs liquid, the mod still works. I wouldn't do this mod on kevlar,
    poly, metal, and other exotic cones. Ever see those fabric dome tweeters
    with sometimes sticky black goo on them? It's a cone treatment {hehe}.
  14. #29
    thadman's Avatar
    May 2005
    Indiana
    1,514
    Im not sure if I would recommend strengthening the cone for such a high crossover. Point being that making the cone more rigid would result in a higher amplitude, but more concentrated peak vs a lower amplitude, wider peak. The result of this would probably be less average distortion over the drivers passband, but one horrendously offensive distortion peak.
    The reason paper cones may subjectively sound good is because they have a warm sound signature, which comes as a result of high levels of distortion that resemble low amplitude *plateaus* rather than high amplitude peaks. This creates a more homogeneous distortion signature, rather than the abrupt, high amplitude distortion peaks associated with metal cone drivers. In most cases associated with stiff coned drivers (often with metal cone drivers), you cross before the high amplitude peak presents itself in the form of 2nd and 3rd order harmonics (ex. you would cross ~1400hz with a Seas W18EX). In your given situation, you are not going to be crossing low so I would advise against it.
    This is just my recommendation and remember to take it with a grain of salt because ive never tested the driver nor the driver with cone treatment. Although you could test the driver to see what works best, it would be counter productive because you could buy a better driver instead of purchasing an additional driver and the cone treatment materials.
  15. #30
    thylantyr's Avatar
    Apr 2005
    1,395
    Have faith.
    The best midranges I've heard come from a French vendor who uses
    paper treated cones. These drivers beat Focal, Seas, etc., in my auditions.
    My NSB's with cone treatments sound so much better than without. Treating
    cones is not a new art.
