Originally Posted by
B@SSAN8OR (power)
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts GREEN IGNITION SWITCH HARNESS
(use ign as acc wire)
(speaker wire)
Driver Passenger Size Location
WHITE (+) WHITE Front 5 1/4" FRONT KICK PANELS
BLACK (-) BLACK
WHITE (+) WHITE Rear 5 1/4" REAR DECK
BLACK (-) BLACK
have fun with the speaker connections. there is probably a factory amp in either the trunk or behind a seat somewhere. you might have to bypass that.
and if there is a volume fader in the center console you will have to bypass that also.
if you going to do it you should probably charge them like $75-100. if they dont want to pay that tell them to go to BB and they will charge about the same. bmws ****.
also dont worry about the illumination wire it is not needed for the deck to work. so dont worry about finding it.
also if you dont have one allready get a multi meter. preferably a digital one
Bookmarks
