I am installing a used Eclipse CD5442 HU and there is a 18" wire with a small box at it's end coming out of the back of the HU. What is this?
Thanks
Thanks
what color is the wire?....im guessing its an inline fuse to your constant so that you dont fry your internal amp, but ive never worked with eclipse decks so i might be talking about my bunghole
1997 Ford Ranger Extended Cab 4.0 V6
20" Centerline Hollywood Wheels![]()
Wrapped in Sumitomo HTR ZII
Alpine-9827
JL Audio VR 6.5" Comps in Kicks![]()
JL Audio TR 6.5" Comps in Rear Fill
JL Audio 6W0's in Center Console![]()
JL Audio 300/4
JL Audio 12W7 in Ported Box, tuned at 32 hz
JL Audio 1000/1
200A Alternator from Motor City Reman.
BIG 3
ALL STREETWIRES CABLES![]()
141.1 dB Legal, 169.9 dB Outlaw![]()
REF'S
nikosbuddy
NjccBflo
bonesninja
DC-DC converter. It converts the power from the car to whatever voltage the decks various circuits need. in the process this can produce a lot of interference, so in theory, somthing better done farther away from the deck.
Yeah, the box is for the amount of Volts is receives and then distributes. I think those have like a 4v preout? But I could be wrong.
looks like i was way off
Alpine-9827
JL Audio 300/4
JL Audio 1000/1
BIG 3
REF'S
nikosbuddy
NjccBflo
bonesninja
Sure were u ignoramusOriginally Posted by bhsswrstlr
Thanks everyone, I would never of guessed it had something to do with the power.
I believe it is the power supply for the display.
2002 Honda Accord SE sedan
RF 8250
Sirius
Dynaudio 220 components
JL Audio 12W6V2 sub
JL Audio 300/4 amp
JL audio 500/1 amp
http://members.sounddomain.com/perryb
This is for the 4 volt preouts.
Makes a world of difference when running an amp.
I'd never hook another amp up w/out running at least 4 volts to it.
Voltage from your HU allows your amp more power and runs cleaner.
Your thinking of the Eclipse balanced line adapter.Originally Posted by BCONNELLY
Its the DC-DC converter. The box he speaks of only has 1 cable connected to it and that's it. No outputs of any kind.
your all wrong. Thats part of the brain. eclipse couldnt fit it all inside so they had to put some of it outside. my deck has the same thing on it.
my 8443 has a dangling box too :O
Wrong. The amp can put out the same amount of power regardless.
I know on the Clarion DRX9255 the external box thingy was the DC/DC convertor. I can only assume the same for the Eclipse's, but I honestly have no idea![]()
Just called Eclipse for all of you. It is the transformer box for the Display. My 8052 has it also.
Bookmarks
