Results 1 to 5 of 5
Reload Thread: Question about HU preout voltage and amp input voltage
    FSUNole17's Avatar
    FSUNole17 is offline Senior VIP Member
    Jan 2005
    franklin, tn
    254
    ok i have a question.... i have a pioneer premier p860 HU and the preouts are 6.5V..... my amp is a rockford fosgate power 1001bd and i read in the manual that its input sensitivity is from 600mV to 6V is my HU too powerful for my amp, i mean would it be sending it too much signal? i really duno because that seems the case, the amp is performing fine right now but i was seein if i should do anything about it, thanks!
    HAVINGFUN's Avatar
    HAVINGFUN is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    2,030
    17
    Re: Question about HU preout voltage and amp input voltage
    You will be fine and you do not have to match them up perfectly. Plus the 6.5 Volts is probably achieved with full HU settings....bass up sub level up and volume maxed etc.
    tRiGgEr's Avatar
    tRiGgEr is offline CarAudio.com Veteran
    Jan 2004
    San Diego, Ca
    30
    12,810
    Yeah you would have to turn your sub level and volume all the way up to reach full 6.5v. You will be fine. Just do the amp gain setting thingy. Read the help guide.
    Quote Originally Posted by Scoobydoo View Post
    Before poking fun at others at least learn to spell. I won't go into all the gammar mistakes!
    Irony?
    Your sig... Im trying to figure out if you think he spelled grammar wrong. Because, he didn't. Irony indeed.
    3.5Max6spd's Avatar
    3.5Max6spd is offline yo mama no wear no draws
    Jun 2004
    Dirty Jersey
    35
    3,767
    you'll be fine......that 6.5v isn't rms, its incremental based on gain setting/volume
    rainbow....homemade sounds best
    DYNAUDIO E S O T E C....Mobile Fidelity
    Panasonic Vacuum Tube
    TRU Technology SSLD6
    TRU Technology STEEL S44 & S500
    DYNAUDIO Esotec System 362
    Dynaudio MW190 12" (x2) IB
    Stinger Expert/Esoteric Audio Isopath/Cascade
    Refs-NE14MX , jdavis37, anarchy57, mj121983 , ll kadoy ll, TheBigDu , cdj ,Kawasaki STX-R ,Fdeez ,Ksin291,meangta, lil azn 06, HAVINGFUN, Loud1500, Flipx99 , jjunior887 ,mastarecoil ,slammed , T3mpest ,westerbud, Airman21, bconn587, LexNBimmer,namike, alphakenny1, HebrewHammer,chadillac,remiserg, purerx7tt, OCURIEL, coneO,Igno,Iluvzmzm,godzukiduce,CrazedCat,skylar11 2,
    bose301s,qwertvt
    Alpine2005's Avatar
    Alpine2005 is offline CARROZZERIA
    Nov 2004
    CA
    559
    yeah i was tiring that the other day to a boss audio amp.
    i was using a panasonic HU with 5v outputs and the amps input sensitivity is .2 to 4V and it worked fine even at high volume
    you'll be fine
  1. Question about HU preout voltage and amp input voltage
    By FSUNole17 in forum General Discussion
    Last Post: 01-26-2005, 04:24 PM
  2. Voltage to Amp
    By brs954 in forum Amplifiers
    Last Post: 11-03-2004, 12:41 AM
  3. Replies: 6
    Last Post: 09-22-2004, 11:52 AM
  4. Input voltage and amp output
    By badboyzx2 in forum Amplifiers
    Last Post: 01-05-2003, 12:14 AM
  5. Replies: 15
    Last Post: 12-20-2002, 08:10 PM
