Results 1 to 2 of 2
Reload Thread: Tuning of Alpine CDA-9811
    iCe_2x's Avatar
    iCe_2x is offline Junior Member
    May 2004
    Tallahasee, FL
    15
    Could anyone give me some tips for tuning this headunit, For some reason, I can't get it to sound right.. I feel like i could use a little more mids, and i can only adjust the treble and the bass...
    thanks
    j3bus2k3's Avatar
    j3bus2k3 is offline Si vis pacem, para bellum
    Aug 2004
    St. Pete, FL
    6,285
    Re: Tuning of Alpine CDA-9811
    I've got the same one...its pretty easy if you sit with it and the manual. If your trying to fix the time correction, use alpine's website.
    Hold the bass button to select base type; the bottom middle key does time correction and bass focus and if you hold it down, you'll get to the x-over options. the MX button will just turn it off or on unless you hold it which will allow you to select which "MX mode" setting to use, i was told number 3 is the best.....
    little hint I learned...Hold the "F" button next to the number 1 on your presets to bring up the setup menu...assuming you have subs, you can turn them off and tune your low, mids, and highs accordingly. Just get the manual from alpine's website and read through it for some more hints or questions.
    AIM: SPL Performance1
    /////Alpine 9835
    Active Processing via Coustic XM7
    Dayton 7" Mid-woofer with Seas Neo Tweet
    JBL/Crown 1100 & Power 300.4
    12" TC3000 Based Custom in 2.25ft^3 at 32hz
    Wallet say But I say
    References:Moe Lester, PV Audio, sss18734, DJ-Torn, dleccord, jiggy2dmax, Negativezeroz, Bama350z, TeamPSI, dB Dom, Kenny Pollock, Flossinon24s, Patfitz9 (x2), AppleBonker, BassAddictJ, the727kid, skadude016, CaliKid, Thumper88, Djman37, TeamQuakeCelica, Cerob, Pimpedout97x, Troy_Audi0, got_focus?, Karleon, Jamaica2G, rtillare, dumple, JohnnyBusa, mattmcss, whitem1ke88, nineball
  1. Alpine CDA 9830 help
    By liar2 in forum Head Units
    Last Post: 12-17-2004, 04:32 PM
  2. Second opinion and reviews on Alpine CDA 7949
    By XCivic in forum General Discussion
    Last Post: 07-18-2002, 03:11 PM
  3. Alpine CDA 7949E equivalent with RDS ...?
    By gnc in forum General Discussion
    Last Post: 04-29-2002, 04:36 PM
