Results 1 to 13 of 13
Reload Thread: 8 volt HU
    Looney_Tune's Avatar
    Looney_Tune is offline F**k How You Feel
    Nov 2004
    Killeen,TX
    27
    2,218
    8 volt HU
    What reasonable priced HU(if any) are there that will give me an output of 8 volts to an external amp?
    I want to be able to crank my gain.
    THANKS
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    40
    14,802
    Re: 8 volt HU
    eclipse has 8V sub-outs i beleive.
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Re: 8 volt HU
    Quote Originally Posted by Looney_Tune
    By "crank" I assume you mean crank it way down?
    Eclispse, as mentioned. Pioneer has some units that are 6.5V
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,368
    Re: 8 volt HU
    What ?
    1. why would you do such a stupid thing
    2. the higher the preout voltage the lower the gain you need
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,516
    1 Post(s)
    Re: 8 volt HU
    You don't really need a hi preout voltage. Just look for HU's with low impedance outputs.
    Nov 2004
    Killeen,TX
    27
    2,218
    Re: 8 volt HU
    I thought you were suppose to match the gain with the ouput voltage the HU puts out. So I figured if I were to buy a HU that has a 8v sub out I would be able to set the gain to 8V.
    BTW, I really dont know much, just a little more than the basics.
    reed8857's Avatar
    reed8857 is offline SRT 4 (neon with balls)
    Dec 2003
    Atlanta/Deployed Kuwait
    264
    Re: 8 volt HU
    Go check out the gain setting tutorial
    "There is not anything in college that I have learned that life did not teach me first"
    Pioneer Premier DEH-P860MP - Head Unit
    Alpine SPX 177R - Componets
    Orion 3002 - Componet Amp
    Alpine SWR-1241D x 2 - Subwoofers
    Soundstream VGA800.2 - Subwoofers Amp
    M (2.71828) r^2 (__) _____
    4 l x^2 ( force)
    ____
    (acceleration)
    Figure that out and you get a cookie
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Re: 8 volt HU
    Yes, it allows you to turn your gain down (setting your gain to 8V is actually turning it down, not up). But, the one of the main advantages to this is reduce possibility for noise from the amp. If your amp has no noise issues at 4V, then 8V isn't going to sound any different. It's also supposed to help reduce the chance for induced noise when being transferred via the RCA wire. But again, if you have no noise with a lower voltage HU, then you aren't going to notice a difference.
  9. #9
    Nov 2004
    Killeen,TX
    27
    2,218
    Re: 8 volt HU
    ok, makes sense
    learned something new. LOL
    THANKS
  10. #10
    soundfx2's Avatar
    soundfx2 is offline Junior Member
    Nov 2004
    orange county NY
    Re: 8 volt HU
    i did a test with a alpine head unit and a rockford head unit. I did the test about a yr ago so i dont remember what model alpine it was but it was 4v and the rockford was 5v. I put in a test cd and at about 1/2 volume on the alpine it was giving out 5% distortion, at about 1.5v. The rockford head unit went all the way up to 5v with less than 3% distortion. So there is alot more to a head unit then how strong its signal is.
  11. #11
    LIGHTBEING's Avatar
    LIGHTBEING is offline CarAudio.com Elite
    Jun 2004
    New Jersey
    866
    Re: 8 volt HU
    So with my Kenwood HU(2 volts) I'll have to crank my gains almost all the way up? Is this not good for the amp? I believe I can get some processor for my unit and it would make the output 4 volts. Is that something I should look into?
    HU: Kenwood Excelon DDX-7015
    Sub Amp: US amps MD2D
    Sub: 12" RE XXX
    Comp Amp: SS Reference 700s
    Comps: CDT HD-62
    Rearfill: CDT CL-6X
    Box: 2.5 cuft after displacement
    Kinetik HC1800
    OG 185a HO Alt
    100 sq ft eDead
    Custom Trunk
  12. #12
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Re: 8 volt HU
    Higher gain = more chance of the amp having noise
  13. #13
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    61
    3,242
    8 Post(s)
    Re: 8 volt HU
    IMO preout voltage is highly overrated. There are plenty of SQ systems out there with 2V preouts. It's worth getting higher outputs if you're buying a new HU, mostly because other specs also improve with upper end models. But using a line booster is a waste unless you're experiencing hiss from the amp. Anything you add inline adds to distortion.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25
    Sub Stage: In process (will be Boston G310)
    Amp: Boston Acoustics GTA-704 4 Ch
    Rear Fill: Boston SE953 6X9's
  1. 7th gen accord owners... HU help...
    By g30ffr3y in forum Head Units
    Last Post: 11-08-2004, 08:56 AM
  2. HU and the SUB
    By marcopolo in forum General Discussion
    Last Post: 10-13-2004, 10:38 AM
  3. Looking for cheap HU, part 2
    By Scarenius in forum Head Units
    Last Post: 10-11-2004, 06:16 PM
  4. Analyzed HU preamp outputs...they don't distort?
    By sumone in forum General Discussion
    Last Post: 09-27-2004, 11:53 PM
  5. HU recommendation for a 2002 BMW M3
    By mav2002 in forum General Discussion
    Last Post: 08-12-2002, 04:20 PM
