Results 1 to 3 of 3
Reload Thread: output problem
    lsufan778's Avatar
    lsufan778 is offline Member
    Oct 2004
    New Orleans, LA
    76
    output problem
    I have an alpine cda-9825 running a pair of boston sl60 and an alpine mrp-200 amp running an infinity 10' dual voice coil sub. The problem is i hardly get any volume from the sub. I have the gain maxed out and the preamp volume on the hu maxed out and the sub barely keeps up with the fronts. Could it be a bad hu bcause the amp and sub worked fine in my other car.
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    45
    14,803
    5 Post(s)
    Re: output problem
    first thing first--read the gain tutorial--its not a volume knob. you could be cooking your amp right now. check your rca connections.
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
    forbidden's Avatar
    forbidden is offline CarAudio.com Elite
    Jan 2004
    CFB Comox, BC, Canada
    49
    1,127
    Re: output problem
    Disconnect one coil from the sub, if the bass response goes way up then you had one coil wired out of phase. Yikes........
    Yeah, whatever
  1. Still have noise problem
    By kev7706 in forum Wiring, Electrical and Installation Help
    Last Post: 11-14-2004, 11:32 PM
  2. Sub power handling equal to amp output, problem?
    By SaturnScott in forum Subwoofers
    Last Post: 03-05-2002, 10:18 PM
  3. Bad distortion problem...
    By Pepete in forum Wiring, Electrical and Installation Help
    Last Post: 03-04-2002, 08:36 PM
  4. Replies: 3
    Last Post: 02-06-2002, 04:23 PM
  5. Amp Class Question
    By CheapPyramidStuff in forum Amplifiers
    Last Post: 01-10-2002, 08:12 PM
