Results 1 to 3 of 3
Reload Thread: installing h/u
    pj_chevy03's Avatar
    pj_chevy03 is offline please ban me
    Jun 2004
    Alabama
    921
    installing h/u
    i'm going to be installing a h/u for the first time pretty soon and was wondering if there are any precautions i should take so i won't short circuit something. i also would like to know if i should use the factory ground or use a new one. by the way its an alpine cda9830
    Quote Originally Posted by unbonyr
    I just took it allitle to harsly I just sick of narrow-minded people
    nas786's Avatar
    nas786 is offline Senior VIP Member
    Sep 2004
    central cali
    216
    9 Post(s)
    Re: installing h/u
    unhook the battery (you NEVER know)
    double check to make sure you connect the right wires together, and you can always use a voltometer (something like that) to make sure the connections are legit....if you have access to one then you should definately do it
    i would recommend grounding straight from the hu, although i don't think it makes much difference, its just better to do a straight ground instead of going through more wire connections
    as far as that, you should be good....good luck
    KaeZoo's Avatar
    KaeZoo is offline CarAudio.com Elite
    May 2004
    Grand Rapids, MI
    1,103
    Re: installing h/u
    Use a wire harness, and do all your crimping or soldering outside the car. Don't cut out the factory plug, and don't attach the harness until all the connections have been made and insulated.
  1. Flush mounting my H/U
    By Frraksurred in forum Wiring, Electrical and Installation Help
    Last Post: 11-10-2002, 02:17 AM
  2. installing a h/u in an escort??
    By bumpin_blazer in forum General Discussion
    Last Post: 10-10-2002, 02:14 AM
  3. Need to know how to install a h/u
    By Inferno13 in forum General Discussion
    Last Post: 06-12-2002, 10:58 PM
  4. Qestion on Older Sony ES h/u
    By Chris51080 in forum General Discussion
    Last Post: 05-14-2002, 10:29 PM
