Results 1 to 7 of 7
Reload Thread: How Do I Stop Head Unit From Skipping
    dumpinnotes's Avatar
    dumpinnotes is offline Member
    Sep 2004
    Omaha
    40
    Icon32 How Do I Stop Head Unit From Skipping
    I have a newer clarion cd player and the bass in my truck shakes every thing in the truck. The cd player skips alot due to the vibration. I have a dash kit that fits it all installed right. I was wondering if any body has any tips to keep the cd player from Vibrating.
    forbidden's Avatar
    forbidden is offline CarAudio.com Elite
    Jan 2004
    CFB Comox, BC, Canada
    44
    1,127
    Re: How Do I Stop Head Unit From Skipping
    Backstrap the cd player, this is a pain in the butt to do in most newer vehicles but may be the only way to solve the issue. If this does not work, then it may be voltage related (doubtful though) but more likely is related to the subs itself. What happens is simple, a laser sled has a resonant frequency, say 55 hz for example. If your subs hit this frequency with enough amplitude, it will cause it to skip. This is not a design flaw but is standard practice. Most of the "meat and potato" lines of cd players are built to hit the price point, this means that they are built for the average consumer and not the die hard bass fiend who is trying to **** air out his lungs with his subs. If this is the case then I suggest a couple of things. One is the new MB Quart NRA450 marine cd player with a 30 second anti skip buffer - problem solved. Second is find a old Panasonic Rebel Gear cd player with a 10 second anti skip buffer - problem solved. Third, upgrade to an Eclipse that has a laser sled with a resonant frequency of 19hz and servos that react instantaneously to situation just like this.
    Yeah, whatever
    taylor's Avatar
    taylor is offline THUNDER TUNES IS A FLAMER
    Jan 2002
    can
    30
    1,509
    2 Post(s)
    buy an alpine h/u with a changer...good luck getting that to skip....
    Justin89T's Avatar
    Justin89T is offline I Drive A Supra
    Aug 2004
    The Third Island of China
    28
    753
    Forbiden, your knowladge is awesome!
    Sep 2004
    asbestos, wa
    41
    you could just chuck it out the window...skipping problem solved!!
    Sep 2004
    Omaha
    40
    Thanks forbidden that is the best response i could ever get. It tends to do it worst when i hit a really low note. If this tells you why the hole truck shakes like this I have 2 15" MMATS in a ranger so every thing shakes like hell in there. Im going to see if i can find one of those cd players i couldnt thank you enough.
    forbidden's Avatar
    Jan 2004
    44
    1,127
    No worries dude, advice is free any time. I only wish there were forums like this 18 years ago when I first started with car audio. FAK this means I've now spent half my life doing car audio. Good times for 18 years. I still continue to learn new things every day and expect to for quite a while yet, this industry changes every year and you have to change with it.
    Yeah, whatever
  1. Installing Mustang Head Unit
    By Marty I in forum Wiring, Electrical and Installation Help
    Last Post: 09-03-2002, 09:55 PM
  2. New Head Unit In BMW 740i...Suggestions?
    By segal3 in forum General Discussion
    Last Post: 08-27-2002, 07:51 PM
  3. Any comments of a Panasonic Head Unit.....?
    By nofriends46 in forum Wiring, Electrical and Installation Help
    Last Post: 04-17-2002, 03:54 AM
  4. subs make head unit skip :(
    By BriGuy1818 in forum General Discussion
    Last Post: 01-17-2002, 10:44 AM
