Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Reload Thread: engine noise after installing HU
    DJ Eric P.'s Avatar
    DJ Eric P. is offline Member
    Jul 2004
    Torrance, CA
    35
    I just installed a Pioneer DEH8400MP. I have a '03 GMC Sierra and replaced the stock HU. On the stock HU I ad two inline output converters with an amp hooked up and there was no engine noise. After installing the Pioneer the engine noise is pretty loud. Any suggestions/advice on what to do/check would be greatly appreciated.
    Thanks,
    Eric
    My ride:
    '03 GMC Sierra w/ 10" lift sitting on 35's
    '95 Civic - current project car soon to be running low 13's
    '05 Toyota Highlander - grocery getter
    my system:
    subs - 2 12" Audiobahn AW1200Q's (yeah I know)
    components - Audiobahn ABC6002Q
    plates - Audiobahn AS64PQ 4x6's
    amps - Audiobahn A6004T & Kicker KX600.4
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    35
    2,811
    Re: engine noise after installing HU
    Check the grounds. I have a feeling it is the HU that is the culprit.
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    32
    2,393
    reground the HU to something solid, right now you are most likely grounding through the entire cd player to the din mounting sleeve.
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
    DJ Eric P.'s Avatar
    Jul 2004
    Torrance, CA
    35
    Quote Originally Posted by nosaj070
    You are right, I was figuring it would be the HU ground but wasn't sure. I'll re ground it in a couple of hours and let you know what happens.
    Thanks,
    Eric
    My ride:
    my system:
    Hooter's Avatar
    Hooter is offline Take off eh!
    Aug 2004
    Castlegar BC
    34
    116
    where do you have the RCAs running in the vehicle?
    1981 Ford f150 two premier 10's two tantrum 300.2's Premier DEH-550mp rev components
    1970 Chevy Monte Carlo, Sony shaft mount tape player (oh ya)
    DJ Eric P.'s Avatar
    Jul 2004
    Torrance, CA
    35
    I have them going from the HU down through the back of the glove compartment, then under the floor through the pass seat, then it goes to the side door sill to the back of the ext cab.
    My ride:
    my system:
    Hooter's Avatar
    Aug 2004
    Castlegar BC
    34
    116
    hmm never had any problems with engine noise running the RCAs in the same place you have run them, but is your Power wire on the oppisite side? could be a bad RCA too, but just try the easy stuff first like a better ground on the deck, or run a wire from the chassis of the deck to the - side of the amp to see if that makes the noise go away
    clarity413's Avatar
    clarity413 is offline Senior VIP Member
    May 2004
    Bakersfield, CA
    242
    I actually had the same problem with alt wine. The ground trace in the preamp on the HU went out. Usually it's from disconnecting and reconnecting RCAs whiel you're installing it. I might of got it from that. Also, my rca plugs are all metal on the outside I have a feeling they rubbed up against with the computer or cigarette lighter when I was installing them. That might have blown the ground trace. Either way it *****!
  9. #9
    DJ Eric P.'s Avatar
    Jul 2004
    Torrance, CA
    35
    Well I regrounded it to anither part of the truck and still have the same problem. I guess the next thing to do is check the RCA's.
    My ride:
    my system:
  10. #10
    ANeonRider's Avatar
    Aug 2004
    Saskatoon, SK, CAN
    35
    2,811
    How is your battery ground?
  11. #11
    DJ Eric P.'s Avatar
    Jul 2004
    Torrance, CA
    35
    Well, I foud something else that was interesting. When the HU is turned off I can still hear the enginge noise so it's gotta be something else other than the HU grounding right?
    My ride:
    my system:
  12. #12
    ANeonRider's Avatar
    Aug 2004
    Saskatoon, SK, CAN
    35
    2,811
    well, then it is your amp grounds.
  13. #13
    dthadamaja's Avatar
    dthadamaja is offline Member
    Mar 2004
    San jose, ca
    42
    are you running a 4 channel amp? if you are make sure all ground from amps including hu is at the same point to eliminate any ground loop. if that doesnt fix the problem then ground it at the battery. and make sure all signal cables are away from power wires
  14. #14
    DJ Eric P.'s Avatar
    Jul 2004
    Torrance, CA
    35
    Quote Originally Posted by dthadamaja
    *hits self in the head with large wooden spoon* now that makes some ****ing sense.
    My ride:
    my system:
  15. #15
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    That won't matter.........
  1. Noise occuring only after installing second set of RCA's..
    By asmox in forum Wiring, Electrical and Installation Help
    Last Post: 04-06-2006, 03:31 PM
  2. Help me get rid of this engine noise before i shoot myself.
    By raga55 in forum Wiring, Electrical and Installation Help
    Last Post: 03-22-2004, 04:57 PM
  3. HELP, major engine noise....
    By cjj2d in forum General Discussion
    Last Post: 03-15-2004, 11:04 PM
  4. engine noise Very Annoying Plse Hlp!
    By JAYMAN in forum Wiring, Electrical and Installation Help
    Last Post: 01-07-2004, 06:58 PM
  5. engine noise
    By rnjronnie in forum Wiring, Electrical and Installation Help
    Last Post: 12-16-2003, 10:56 PM
