Results 1 to 10 of 10
Reload Thread: Pioneer Vs. Premier - What's the Difference?
    MonkeyBizIU1859's Avatar
    MonkeyBizIU1859 is offline MOTHERF'IN' SNAKES
    Jul 2004
    Indianapolis, IN
    29
    46
    Okay, so I'm shopping around on a new head unit, and I finally find one I like, the Pioneer Premier DEH-960MP. Well, it seems like almost the exact same head unit is available from Pioneer for $100+ less. So, would I be getting someting extra with the Premier that makes it worth it, or just getting shafted? Thanks.
    Duffman says a lot of things he doesn't mean! OH YEAAAAAH! ~Duffman~
    Grease me up woman! There's nary an animal alive that can outrun a greased Scotsman! ~Groundskeeper Willy~
    Now don't you be readin' my mind between 4 and 5. That's Willy's time! ~Groundskeeper Willy~
    JLCivic's Avatar
    JLCivic is offline CarAudio.com Elite
    Mar 2003
    Maine
    44
    1,211
    Re: Pioneer Vs. Premier - What's the Difference?
    Premier has a longer warranty when purchased from an authorized dealer, and some premier units have higher pre out voltage. Just compare the 2 decks. You should be able to get all the info you need from Pioneer's website.
    2002 Honda Accord SE sedan
    RF 8250
    Sirius
    Dynaudio 220 components
    JL Audio 12W6V2 sub
    JL Audio 300/4 amp
    JL audio 500/1 amp
    http://members.sounddomain.com/perryb
    Jul 2004
    Indianapolis, IN
    29
    46
    Okay. The Pioneer has 4v preouts, and the Premier has 6.5v preouts. What's the diff? What's it going to sound like?
    bigpeen's Avatar
    bigpeen is offline Member
    Jul 2004
    Kansas City, Omaha, Ames (Iowa State)
    78
    It is going to sound like someone just gave your deck an extra 2.5 volts. It will be a cleaner and stronger signal to the amps, and YES it makes a difference IMO. I had a premier 6.5 volt outut last year and went to an Alpine w/ 2volt and OMFG..it was as clear as night and day. Go the extra ducats if you can and go Premier, a few more feautres and its the top of the line from Pioneer.
    01 Chrysler Sebring
    2 Kicker DX 700S
    2 12in Kicker L7 Solos
    Alpine CVA 1004
    Alpine 6 Disc MP3 changer
    Clarion VCZ628 In-Car 6 Disc DVD Changer
    4 Pioneer 6990R 6X9 5-Ways
    X-Box
    3 more monitors coming soon...
    "Four 15's didn't see no wires...then I heard BOOOM from the amplifiers"
    Hmmmmm...sounded good in the song...but makes no **** sense in reality. Just a thought.
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Midwest Ohio
    26
    3,509
    so let me get this right Premier is Pioneer's high end stuff
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    desi_daru's Avatar
    desi_daru is offline CarAudio.com Elite
    Nov 2003
    BC, Canada
    543
    yes, premier is pioneers high end stuff
    Car - 04' Honda Civic Si, silver
    Deck - Clarion ProAudio DXZ835MP
    Fronts - Alpine Type-R SPR-136A (5.25" comps w/ 1" tweet)
    Speaker Amp - MTX Thunder404
    Sub - 1x Rockford Fosgate RFP3412 ported box
    Sub Amp - Rockford Fosgate Punch 150S
    Wiring - power/ground 4guage, speaker 16guage
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Quote Originally Posted by bigpeen
    Did you re-adjust the gains or just drop the Alpine in without re-adjusting anything?
    Jul 2004
    Indianapolis, IN
    29
    46
    Well, it's going from 4v to 6.5v. The features are identical, with the exception of the preouts. Honestly, it can't be that much different to be worth the extra $100+ I'd be paying for it, so I'm just going with the straight Pioneer instead.
  9. #9
    3.5Max6spd's Avatar
    3.5Max6spd is offline yo mama no wear no draws
    Jun 2004
    Dirty Jersey
    35
    3,767
    Quote Originally Posted by MonkeyBizIU1859
    Theres a fine line between what you need and what you want......I've made those same judgement calls in the past and was never happy until I got what I wanted-Its worth the extra $100 if having the best Pioneer has to offer is important to you
    rainbow....homemade sounds best
    DYNAUDIO E S O T E C....Mobile Fidelity
    Panasonic Vacuum Tube
    TRU Technology SSLD6
    TRU Technology STEEL S44 & S500
    DYNAUDIO Esotec System 362
    Dynaudio MW190 12" (x2) IB
    Stinger Expert/Esoteric Audio Isopath/Cascade
    Refs-NE14MX , jdavis37, anarchy57, mj121983 , ll kadoy ll, TheBigDu , cdj ,Kawasaki STX-R ,Fdeez ,Ksin291,meangta, lil azn 06, HAVINGFUN, Loud1500, Flipx99 , jjunior887 ,mastarecoil ,slammed , T3mpest ,westerbud, Airman21, bconn587, LexNBimmer,namike, alphakenny1, HebrewHammer,chadillac,remiserg, purerx7tt, OCURIEL, coneO,Igno,Iluvzmzm,godzukiduce,CrazedCat,skylar11 2,
    bose301s,qwertvt
  10. #10
    s5pitfire's Avatar
    s5pitfire is offline Ello?
    Jul 2004
    Sacto, CA
    186
    I almost got the 450MP premier instead of the regular DEH 4600, but i would have had to spend another $40 or $50 and i would have got another .8 volts for preout. meh.
    R.I.P Love Park
  1. Pioneer Premier DEH-P860MP
    By diddy0071 in forum Head Unit Reviews
    Last Post: 06-19-2004, 11:30 PM
  2. Sony CDX-M620 vs. Pioneer Premier DEH-P900R
    By phatrabbitzz in forum General Discussion
    Last Post: 06-04-2004, 12:23 AM
  3. Replies: 2
    Last Post: 03-13-2004, 01:15 PM
  4. Pioneer Premier PRS-X320?
    By KJL_21 in forum Amplifiers
    Last Post: 03-02-2004, 03:15 PM
  5. Premier Pioneer DEH-P650 vs Premier Pioneer DEH-550MP
    By AndrewD1022 in forum General Discussion
    Last Post: 08-08-2003, 01:12 AM
