I NEED HELP HOOKING UP AN AMP AND BOX TO MY FACTORY HEAD UNIT 98 MALIBU. MY BIGGEST PROBLEM IS NOT KNOWING HOW TO GOT TO OR PULL OUT MY HEAD UNIT. IF ANYONE HAS DONE THIS BEFORE OR JUST KNOWS HOW PLEASE HELP ASAP.
I have a 2000 malibu, and if it's the same, all you have to do is:
1. pull out the black trim piece. don't worry, just pull on it; the thing over the key socket will fall off too.
2. then all you gotta do is remove those two screws, pull out the radio, and disconnect the wires
%0message=I have a 2000 malibu, and if it's the same, all you have to do is:
then to put it back on just put the key socket thing inside the trim, and press the trim back into place.
best sig of all time
Bookmarks
