+ Reply to Thread
Results 1 to 12 of 12
Reload Thread: New headunit. Lower volume/sound quality
    Justin000's Avatar
    Justin000 is offline Junior Member
    Dec 2017
    Canada
    3 Post(s)
    I replaced the stock head unit with a Kenwood Excelon DDX6904S. $1,000 head unit...
    The new head unit is about half the volume and half the sound quality of the stock head unit. At 75% volume the heat and road noise drown out the stereo.
    I've installed at least a couple dozen head units before and never had any issues of lower volume and worse quality.
    The new head unit says 4-8 ohms, my trucks speakers (stock) are all 4ohms.
    Iíve double checked all my wires, nothing is out of phase, or connected poorly.
    Iím seriously about to return this headunit and go install my old $65 pioneer headunit from my work truck. At least that HU didnít botch my system.
    Any suggestions/explanations?
    My vehicle is a 2011 Chevy Silverado 1500 LT, crew cab, no Bose, no dash speaker, no factory amp (99% sure about the amp), tweeters on the front columns, 6.5s in the 4 doors.
    youdoofus's Avatar
    youdoofus is offline Well, hello Mr.Fancypants
    Dec 2014
    the void of space called the midwest
    2,367
    6 Post(s)
    1049 Post(s)
    Re: New headunit. Lower volume/sound quality
    Quote Originally Posted by Justin000 View Post
    could be that the unit you got was mainly intended to be a dead head and therefore has a weaker internal amp. Those lower end units have decent internal amps as theyre not usually run with an amp hence their 2 volt pre outs
    also, its not a $1000 deck, its available for $550 on amazon
    2002 Honda Accord sedan V6 (automatic slushbox)
    2 Rockford p3 12s (dual 2 ohm)
    Pioneer AVH-2300NEX
    2 PPI PC275's running 1 sub each atm, waiting to put the SQ 2200.1 back in and add the PhoenixGold Elite.4 once my electrical is up to snuff
    Front stage:PRV Audio 6MB200 6.5 and Massive Audio CT2 tweeters
    Rear speakers: stock
    I just added 5 SoundQubed stickers, and despite having no equipment upgrades, it added 76 DB!!!
    JonM's Avatar
    JonM is offline Member
    Jan 2017
    Columbus Ohio
    142
    77 Post(s)
    It's got 22 watts x4 so you should be good on watts. I've got the ddx6702s and never had any volume issues.
    Kenwood 6702s
    Fosgate component 6.5s T2652-s front/T1693 6x9s rear
    Ohio generator 300amp alt
    2 XS power 3100d
    1 run 4 OTT and 1 run 4 gauge OFC power
    HCCA 8000.1 sub amp. audiopipe 2004 mids and highs
    2 dual ohm 12" 2,500 watt HCCAs
    Custom box tuned to 36 hertz
    Justin000's Avatar
    Dec 2017
    Canada
    3 Post(s)
    Turns out the Maestro module I was using had inline resistors on the speaker wire. I cut them out and all was fixed. Just in case someone else had a similar issue.
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    If you using this decks internal amp you need to catch your head
    Dec 2006
    New orleans LA
    32
    13,691
    70 Post(s)
    2 Thread(s)
    5721 Post(s)
    I'll give you 350 for it right now
  7. 01-29-2018
    Banned
  8. #7
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,539
    42 Post(s)
    6181 Post(s)
    $1000 HU? It better wipe my *** for me
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    Soundstream Rubicon 1.2500D & 4.500 amps (New amps coming soon)
  9. #8
    Jul 2005
    WA
    14,539
    42 Post(s)
    6181 Post(s)
    Quote Originally Posted by bluemind View Post
    so much expensive for a HU. But the quality is so *****. You better to try this HU just $259 and way better than Pioneer and Kenwood https://www.amazon.com/ATOTO-Navigat.../dp/B075W9GMPF
    Better than Pioneer and Kenwood in what way? Have you done side by side testing against link provided? I would not get that no name HU just because of the flashy colors/bright screen.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  10. #9
    Justin000's Avatar
    Dec 2017
    Canada
    3 Post(s)
    I was only using this headunits internal amp with the stock speakers until I had a chance to install the rest of my system. I live in Canada and we get like 2 feet of snow every week so I’m not very motivated to go work outside lol.
  11. #10
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    18,397
    110 Post(s)
    7905 Post(s)
    Itís internal amp is rated at 10% THD. GFY
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    Zapco ST-4X SQ, ST-1000XMii
    IDQ12v4 1.8cu sealed
    Alpine SPX Pro ring radiators
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  12. #11
    shredder2's Avatar
    shredder2 is online now CarAudio.com Elite
    Nov 2017
    Phoenix Az
    1,504
    42 Post(s)
    600 Post(s)
    This guy again?.. lol
    Recommendation please
    Are you human?
  13. #12
    gmctrucks's Avatar
    gmctrucks is offline Member
    Feb 2011
    Houston, Texas
    79
    22 Post(s)
    My Alpine HU is 50X4 but I turned off the hu amp because Iím pushing it with a JBL amp now and it sounds killer to me.
+ Reply to Thread
  1. hooked up new headunit. but no sound?
    By atlninja82 in forum Wiring, Electrical and Installation Help
    Last Post: 08-08-2010, 02:48 AM
  2. new sound quality setup what do you think?
    By 88irocZ in forum Speakers
    Last Post: 03-30-2007, 03:01 PM
  3. So-So Sound quality from my new Pioneer P780MP
    By ty1er in forum Head Units
    Last Post: 06-23-2006, 07:45 PM
  4. Sound Quality/Volume with MP3s
    By sungwei in forum General Discussion
    Last Post: 05-02-2004, 04:23 AM
  5. Best Sound Quality Sub for new car 2003 Passat
    By CarAudioNut in forum Subwoofers
    Last Post: 02-22-2003, 04:56 PM
