+ Reply to Thread
Results 1 to 11 of 11
Reload Thread: Pioneer time alignment
    MikeCL's Avatar
    MikeCL is offline Member
    Jul 2013
    Connecticut
    30
    11 Post(s)
    Icon32 Pioneer time alignment
    It was my first time messing with it but the readout was in inches so I assume the distance between me and the speaker, If I understand right most people just measure and enter in the number? Does it really sound that much better? I played around with it but it still made the driver front way too loud.
    Popwarhomie's Avatar
    Popwarhomie is offline Team Lethal Pressure
    Jan 2010
    Jacksonville, FL
    5,390
    66 Post(s)
    2501 Post(s)
    Re: Pioneer time alignment
    I used auto time alignment with my 2 80prs headunits and really liked the difference.
    2016 Focus ST3 - Rockford DSR1 / PPI 900.4 / Silverflute 6.5" mids / Massive CT2 tweeters /Sundown Xv2 15"/ Taramps DSP3k / Stinger Roadkill / KNU wiring / Northstar SMSAGM80 /
    2010 Focus coupe [email protected]
    Pioneer 80prs /(8) FU Audio 750 12"s / (4) FSD 2600s / (1) FSD 125.4 / (1) FSD 85.4 / (4) Crescendo UN-10" mids / (4) Crescendo FT1 tweeters / Stinger Roadkill / 2/0 EB flex wire / (5) Powerware 90AH batteries / DC 270XP Alt /
    https://www.youtube.com/popwarhomie
    Quote Originally Posted by XxAndreaxX View Post
    too many freq at once, burn the coil, we all know, over 40-50hz, its all coilburning material.
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is online now CHEAP A/F
    Jan 2017
    NC
    6,733
    17
    30 Post(s)
    2685 Post(s)
    Quote Originally Posted by MikeCL View Post
    if u turn it up it doesn't go to ft?, my kenwood does..
    KENWOOD X301 HU, PRECISION POWER Phantom 1000, FU 750 12, 2.1cfad ported, soundqubed 6.5" coax/doors, hp & lp xover on hu, AGM starting batt...
    2 ohms rule
    jar1zx's Avatar
    jar1zx is offline CarAudio.com Elite
    Feb 2011
    Nashville Arkansas
    44
    576
    166 Post(s)
    I've ran 3-4 flagship pioneers and I didn't like the sound of the auto TA.
    Think this 8500 has it.........but can't remember if I used auto ta on this deck. If i can find mic I may give it a go.
    08 ext cab z71
    Hu pioneer avh-8500........prs80
    Mechman 320 and a Gp 370 with dual alt bracket
    northstar 34 and 480 with gp terminals for both
    Ton of ofc 2/0 and smd fuse blocks
    Soundqubed hdc4 12's
    Soundqubed 6.5's two sets
    crescendo concerto c1100.4
    Sound digital evo 12k
    Sguirrelfeather's Avatar
    Sguirrelfeather is offline Senior VIP Member
    Feb 2016
    Mountain Home, ID
    200
    2 Post(s)
    81 Post(s)
    I have the AVH-490 and it stays in inches the whole way through. You have to be careful and follow the directions, then tweak a little more. I don't know why, but if you go in the wrong order it will attempt to adjust the volume on the speakers as you change the time, but when it does that it does it in the wrong direction. I honestly can't remember the order which eventually worked perfect for me, but what I did in the interim was set distance and then immediately changed all of the individual speaker adjustments to zero so I could begin working on that aspect as well.
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,187
    245 Post(s)
    7915 Post(s)
    Measure the Inches from the driver to your ear. Thats only the first step. Before doing that, make sure your right and left RCAs are correct, some people mess up and their left and right sides are switched.
    After you enter the initial inches, Mute the sub and tweeter, then work on the midrange. You can choose either the left or right side values, you just need to subtact or add and actually see how the sound stage shifts left or right, to do this, you'll want a centered vocal track, for example, echosmith- bright. When you hear the vocals directly dead center right under the rear view mirror thats when your time alignment is centered and proper. Now turn off the mids and do the same thing with the tweeters.
    Make sure your speaker level values are zeroed out. Sometimes when you initially set the listening position to front left, pioneer has wierd @ss speaker level values that attenuate the right side.
    Auto time alignment and EQ is complete trash lol totally off center and the auto EQ fks with everything and will clip the sh*t out of your setup.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    MikeCL's Avatar
    Jul 2013
    Connecticut
    30
    11 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    Yeah man that's what I did when I set it to front left it was like WOW all I hear is all of the right side.. but I will measure and see I assume after all that it would still need some light tweaking?
    MikeCL's Avatar
    Jul 2013
    Connecticut
    30
    11 Post(s)
    Sorry for the delay finally got it set up but I noticed it was still very loud on the drivers side and I noticed for the sound levels for the speakers it was something like +6 and -3 for the passenger side now that it's balanced plus the TA vocals sounds like it's coming from the center now.
    Still not done yet however but it sounds better and will be much better when I can rip that plastic off the door
  9. #9
    Jeffdachef's Avatar
    Feb 2013
    16,187
    245 Post(s)
    7915 Post(s)
    I did say in post 6 to make sure your speaker levels are zero'd out lol. The setup will continue to sound better and better. Especially if you got the active crossovers and slopes and EQ on point.
  10. #10
    MikeCL's Avatar
    Jul 2013
    Connecticut
    30
    11 Post(s)
    lol crap I must of missed that.. one other thing that I'm not too sure of is the crossover and the slope setting typical components are around 12db?
  11. #11
    Jeffdachef's Avatar
    Feb 2013
    16,187
    245 Post(s)
    7915 Post(s)
    its just experimentation to see what points and slopes provide the smoothest response.
  12. Likes MikeCL liked this post
+ Reply to Thread
  1. how to set time alignment for pioneer HU
    By frankiebones in forum Head Units
    Last Post: 12-06-2006, 06:53 AM
  2. Replies: 6
    Last Post: 12-04-2006, 10:34 AM
  3. Pioneer Time alignment
    By dishon22 in forum Head Units
    Last Post: 09-22-2006, 11:30 AM
  4. presets for time alignment on alpine cda-9833
    By orlmailman in forum General Discussion
    Last Post: 04-06-2004, 04:19 PM
