+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Reload Thread: Not enough receiver power?
  1. #16
    shredder1's Avatar
    shredder1 is offline CarAudio.com Elite
    Dec 2013
    Phoenix, AZ
    1,424
    14 Post(s)
    671 Post(s)
    Re: Not enough receiver power?
    Quote Originally Posted by Tynan View Post
    Heres a video I just shot...
    https://youtu.be/289_HYEJuCo
    That sounds pretty bad... LOL!.. are you boosting the bass on the deck?.. is there a sub in the system or are you playing ALL frequencies thru your speakers?.. in addition to your signal/power problems it sounds like you're trying to play some LOWS thru your speakers...
    Maybe some bass blockers are a partial solution?...
    The Budget Beater Blazer Build... Lookin' for those Basshead Problems!
  2. #17
    youdoofus's Avatar
    youdoofus is offline Well, hello Mr.Fancypants
    Dec 2014
    the void of space called the midwest
    1,300
    5 Post(s)
    556 Post(s)
    Quote Originally Posted by shredder1 View Post
    bass blockers... i had to go back and double check if that deck had a HPF or not, doesnt look like it does. OP, youre probably gonna be best served spending a little cash on a better deck.
    Are you streaming your audio from something like pandora or using mp3 files?
    If youre using mp3 files, just get a flash drive or make a few mp3 discs, youll be so much better off sound quality wise. Or something with bluetooth so you can still use your phone to select the songs
    2002 Honda Accord sedan V6 (automatic slushbox)
    2 Rockford p3 12s (dual 2 ohm)
    Pioneer AVH-X4500bt
    SQ 2200.1
    Stock front and rears (theyre actually squirrels listening to headphones that ive trained to sing what theyre hearing)
    I just added 5 SoundQubed stickers, and despite having no equipment upgrades, it added 76 DB!!!
  3. #18
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    13,636
    156 Post(s)
    6350 Post(s)
    What about this deck?
    jvc kd-r520
    garbage.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  4. #19
    youdoofus's Avatar
    Dec 2014
    1,300
    5 Post(s)
    556 Post(s)
    Cool shorts btw anyways, the video sounded like what the movies make alien transmissions sound like. Might just be my data connection tho. I'll have to look again at home. But shredder sounds like he already diagnosed it for ya, plus going max volume on both sources isn't good
    ok, just checked it on my home system, and it still sounds like an alien is trying to abduct you or inject an audio snippet to reprogram our brains
    Pioneer AVH-X4500bt
    SQ 2200.1
  5. #20
    tymoto21's Avatar
    tymoto21 is offline CarAudio.com Elite
    Apr 2008
    wisconsin
    742
    158 Post(s)
    is it possible the aux jack isn't going in all the way and making intermittent connection with the radio
    That would cause cracklings and quiet
  6. #21
    BOOMINGRANDPA's Avatar
    BOOMINGRANDPA is offline YEAH I'M A CHEAP BAST*RD BOOMINGRANDPA is a Supporting Member of the forum!
    Jan 2017
    NC
    2,545
    15 Post(s)
    1008 Post(s)
    I have a Panasonic CQ-RX100U receiver (50x4 watts). I just bought 2 Dual 6 1/2 4 way DLS654 speakers (160 watts each) and 2 Dual 6x9 4 way DLS694 speakers. I use my aux and mobile phone to play music. My problem is the static when my phone volume is all the way up and my receiver volume is all the way up. The speakers are brand new, so I know it isn't the speakers. Is it because my receiver doesn't put out enough power to play audio to it's full potential? Should I buy another receiver or buy an amp?
    well i finally got an answer from guy in ny had hiss type problem with phone/hu last week his was the bt volume was at +4 so if u have any type of auto volume boost (same volume per source) try turning that off check hu setting is what i'm saying, turn all eq's and all down see if that helps..
    KENWOOD X301 HU , PIONEER CHAMP PRO 3003d4 12, 1.65 CF SLOT PORTED TUNED TO 35 HZ, PRECISION POWER P1000, SOUNDQUBED 6.5" coax, xover (hu) AGM starting batt. https://www.youtube.com/watch?v=rTcgVGvuFX8 https://www.youtube.com/watch?v=WI4yGDqN27g
  7. #22
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    9,880
    24 Post(s)
    4159 Post(s)
    Or just buy a decent 4 ch amp and quit maxing out the HU volume. Problem solved.
    97 4 dr. Tahoe
    Optima redtop
    Alpine 9835
    Polk Audio MM6501 comps
+ Reply to Thread
  1. not enough power to amp
    By HYmanDR0ne in forum Wiring, Electrical and Installation Help
    Last Post: 02-25-2004, 08:48 AM
  2. not enough power to a sub?
    By greenchaos in forum Subwoofers
    Last Post: 01-23-2003, 08:29 PM
  3. XTRPRO subwoofer problem, not enough power?
    By cygnus in forum Wiring, Electrical and Installation Help
    Last Post: 05-10-2002, 02:17 AM
  4. Is there such thing as not enough power?
    By puppie_chow in forum Wiring, Electrical and Installation Help
    Last Post: 04-17-2002, 06:59 AM
  5. not enough power?
    By freddrick in forum Subwoofers
    Last Post: 02-19-2002, 10:37 PM
