Results 1 to 7 of 7
Reload Thread: Running head unit on 1 ohm speakers?
    kozzy7778's Avatar
    kozzy7778 is offline Junior Member
    Jan 2017
    Pensacola, FL
    Hello,
    Without going into a super long story about what happened, I ran my Alpine CDE-164BT head unit while it was hooked up to the stock Bose speakers in my 2002 Nissan Maxima. I found out after having them hooked up for about a month and listening to music super loud that they are 1ohm speakers and could potentially damage the head unit. The shop that installed it MAY have installed it correctly but a lot of signs point to them bypassing the factory amp and just hooking up the 1ohm speakers directly to the head unit. Once I found that out I stopped listening to music altogether or listened to it very quietly.
    That being said, all I want to know is this:
    I could care less if I damaged the internal amp of the head unit, all I care about is if there is ANY potential that I damaged something within the head unit that would effect sound quality once I hook it up to an external 4-way amp. Is the ONLY thing that could have potentially been damaged the internal amp? Or is there a chance running them as loud and for as long as I did for that month may have damaged some other part of the head unit, internal or even external like the outputs?
    Is there such thing as a head unit it being "slightly damaged" or is it one of those "it's either working correctly or it's not turning on, there's no in between" types of things?
    I really appreciate your help, it will bring me peace of mind to know whether or not I should just replace it or if I should be good to go!
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,295
    41 Post(s)
    6057 Post(s)
    Re: Running head unit on 1 ohm speakers?
    1 ohm speakers? For a stock system? That doesn't sound right. Do you know that for sure or just going by what they told ya?
    If the Alpine still works and functions properly, I'd say keep using it. The HU only puts out xx number of watts into 4 ohms btw.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    kozzy7778's Avatar
    Jan 2017
    Pensacola, FL
    I'm confident that the stock speakers are 1 ohm. It's a Bose system that has its own external amplifier and 8" subwoofer, it just comes stock in some '02 Maximas. I know that 1 ohm speakers coming stock are not typical but in this case Bose opted to use 1 ohm speakers.
    That being said, running 1 ohm speakers on a head unit designed to put out wattage at 4 ohms is a recipe for overheating the head unit big time. I'm just hoping someone here can speak to the potential damage I am looking at, namely whether or not ANYTHING about the head unit besides the internal amp in the head unit could have been damaged. This includes outputs, internal components, etc. Anything other than the internal amp.
    pickup1's Avatar
    pickup1 is offline CarAudio.com Veteran
    Aug 2005
    Roanoke,TX
    53
    8,469
    19
    7 Post(s)
    840 Post(s)
    Probably just burn up the internal amp.
    BSchrowang's Avatar
    BSchrowang is offline Budget Builder
    Apr 2016
    Peru Illinois
    491
    198 Post(s)
    Ive tried running a 4 ohm sub on an 8 ohm amp and it burned it up in a matter of seconds.
    2010 Ford Crown Victoria Police Interceptor:
    2 American Bass XFL 15"s
    8 cubic foot box
    Taramps HD 3000 at 1 ohm
    Soundbox 1/0 CCA wire
    200 amp police alternator
    kozzy7778's Avatar
    Jan 2017
    Pensacola, FL
    Quote Originally Posted by BSchrowang View Post
    Hmm, so it sounds like you think that running 1 ohm speakers off of a 4 ohm head unit wouldn't have lasted anywhere close to a month if they were wired incorrectly?
    Slo_Ride's Avatar
    Slo_Ride is online now Take It Easy
    Oct 2005
    Atlanta
    13,256
    35 Post(s)
    3231 Post(s)
    Yes his factory speakers are 1 ohm.
    Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
Tags for this Thread
