Results 1 to 5 of 5
Reload Thread: 2011 Silverado Backup Camera w/ stock HU
    Hybrid13's Avatar
    Hybrid13 is offline Junior Member
    Aug 2009
    Coden, Al
    26
    3 Post(s)
    Icon9 2011 Silverado Backup Camera w/ stock HU
    I have a 2011 Silverado with the Bose package and the Nav HU. I would like to be able to turn on the stock backup camera while in drive. It would be useful for when I'm towing my boat. I have found the wire that sends power to the camera and have wired it to an accessory wire to come on with the truck. I having trouble figuring out how to make the HU swap the the camera mode/input. I tested all the wires going into the back of the HU for any change in voltage from park to reverse but found none. I'm kinda leaning toward it being some kind of signal rather than a measurable voltage. Any ideas? All help is greatly appreciated.
    los33's Avatar
    los33 is offline Car Audio G
    Apr 2014
    Houston, TX
    3,524
    29 Post(s)
    2249 Post(s)
    Re: 2011 Silverado Backup Camera w/ stock HU
    If it came stock as a truck option then you would need a ecu flasher to change the setting as none of the electrical is run by transmission switch.
    Hybrid13's Avatar
    Aug 2009
    Coden, Al
    26
    3 Post(s)
    Well what exactly is telling it to switch to the camera input?
    Hybrid13's Avatar
    Aug 2009
    Coden, Al
    26
    3 Post(s)
    los33's Avatar
    Apr 2014
    Houston, TX
    3,524
    29 Post(s)
    2249 Post(s)
    Its a signal coming from the prndl switch sensor.
    If you follow the wire going to the transmission youll find a wire that goes to the camera and one to the ecu.
    To bypass it youll need to get the wire that goes to the ecu and camera and add on a wire that connects both with a switch to turn it on and off.
    Or have someone change your computer for you.
    Changing the computer will block access to the radio since both cant be on.
    So really a bypass will be needed.
  1. hook up amp to stock HU 2003 silverado HD
    By chornet44 in forum Wiring, Electrical and Installation Help
    Last Post: 11-06-2009, 02:41 PM
  2. installing eq and amp to stock hu
    By treefitty in forum Wiring, Electrical and Installation Help
    Last Post: 12-18-2002, 06:27 PM
  3. how do u wire an amp to a stock HU?
    By b16_na in forum Amplifiers
    Last Post: 04-20-2002, 07:12 PM
  4. how do u wire an amp to stock HU?
    By b16_na in forum General Discussion
    Last Post: 04-20-2002, 10:01 AM
  5. Stock HU and 8-pin DIN connector (Acura)
    By GSR Jay in forum General Discussion
    Last Post: 04-14-2002, 06:07 PM
Tags for this Thread
