Results 1 to 2 of 2
Reload Thread: head unit cuts out
    jonathanf's Avatar
    jonathanf is offline Junior Member
    Jul 2014
    Caruthersville, Mo
    head unit cuts out
    I need some help I have a pioneer deh-17 head unit it's about 8 years old I use it outdoors on trips it is hooked to a deep cycle battery power wire and acc are hooked to pos and ground is hooked to neg now my problem if I'm running it without an amp from the speaker wires on the back after about volume 18 it starts cutting out then if you go up more it will power off then back on and keep doing this til you turn it down but if it is hooked to an amp it works fine what could my problem be?
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Re: head unit cuts out
    Sounds like the speakers you're using are too much load for the HU amplifiers, or you have a short in the speakers somewhere.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. Head Unit Cutting Out?
    By gatorgrizz27 in forum General Discussion
    Last Post: 04-24-2006, 09:17 PM
  2. Head Unit Cutting Out?
    By gatorgrizz27 in forum Head Units
    Last Post: 04-18-2006, 07:00 PM
  3. Head unit cuts out when turned up
    By bigbirney420 in forum Head Units
    Last Post: 07-25-2005, 01:06 AM
  4. Head Unit Cutting Out!
    By hargenoff in forum General Discussion
    Last Post: 07-27-2003, 11:47 PM
  5. Head unit cuts out when I use AC
    By Topdawg2982 in forum Wiring, Electrical and Installation Help
    Last Post: 08-01-2002, 01:28 AM
