Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: Noob help: Just got a new head unit, and everything sounds worse
  1. #16
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,843
    109 Post(s)
    7612 Post(s)
    Re: Noob help: Just got a new head unit, and everything sounds worse
    There are plenty about EQs but there are many more just bad post telling people to turn the EQ all the way up. I already said what the EQs purpose is. It is to CUT peaks and smooth out the curve. You can also use the EQ to move around the image if you understand how to.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  2. #17
    mickdeez's Avatar
    mickdeez is offline Junior Member
    Jul 2014
    NC
    2 Post(s)
    Dayum. So its obviously about personal pref here, lol. Currently, here is what I have found to sound the best, but I still need some help:
    HPF: 100hz
    bass boost: off
    EQ: powerful (flat makes it like 2x quieter and 2x less bass, but is subject to change)
    Loudness: Low (again, off makes it so much quieter)
    SLA: +1
    Sub W.: 80 hz +5 -12
    They're sounding a little better now with those settings, but it's like theres a TON of kick, but not much bass.
    Amp settings are:
    Gain: 2
    LPF: 100 hz
    Bass boost: 0.5
    Adjusting the gain helps with the bass alot, but I've always heard to keep gain below 2. Any suggestions? preciate all the help so far.
    Also - could someone help explain the hz **** to me like im five years old? Is lower hz better for lower notes or what?
  3. #18
    negolien's Avatar
    negolien is offline CarAudio.com Elite
    May 2014
    Sacramento,CA
    1,185
    3 Post(s)
    412 Post(s)
    The gain setting is not as easy as just keep below 2 unfortunately. They have people on here that can explain it but to be honest as a beginner you're never going to be able to set that gain yourself. Gain makes a huge difference on whether your audio sounds good or not. The LPF might be better at 80 but your settings are pretty close to mine. I have my HPF set to off though someone might have a better setting for that..
  4. #19
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,843
    109 Post(s)
    7612 Post(s)
    Gain is not a number. It's there to match your head units preout voltage. If you do it right and it's not enough then you need to change either the box or add power or cone area. It sounds to me like if you set it right it's not enough but when you add in distortion from the loudness or to much gain it's good. That's what causes speakers to burn up. I'll look up your head unit and give you a rough, safe idea where it should be.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  5. #20
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,843
    109 Post(s)
    7612 Post(s)
    It will be fine a small click over half gain. Turn the loudness(distortion) off.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  1. Replies: 25
    Last Post: 05-11-2014, 10:08 PM
  2. Just put a new head unit in - terrible sound quality/static... help?
    By soxfan2546 in forum Wiring, Electrical and Installation Help
    Last Post: 07-17-2011, 09:38 PM
  3. need help picking out a new head unit
    By Jamie79 in forum Head Units
    Last Post: 04-27-2007, 08:35 AM
  4. Installed new Head Unit and no sound?
    By viperrgh2 in forum General Discussion
    Last Post: 12-04-2006, 07:49 PM
  5. Other thread got ****ed: new head unit time
    By pwnt by pat in forum Head Units
    Last Post: 03-20-2006, 06:00 PM
