neo_styles ; @
ciaonzo ; @
TheUnderFighter ; @
gckless ; @
nismos14 ;
Regardless, the headunit dims with headlights. had a small scare, it wasnt turning on initially when I had my key in ignition at auxillary.. but i just had to push power :p ooops
Btw, Im kind of upset with the slopes only being 6db & 12 db. But for 160$ i suppose I cant bit
ch
I felt people have praised it up to be what its not.. I love the 5volt preouts, I can tell a difference.
Also, not sure if I need to switch my rca's but when I eq'd the fade or whatever and set it to +5 or so to left.. the right speaker got louder (opposite)
You probably have them rolled. Just switch them and you should be fine.
Heres my setup (granted I need to relocate my tweeter at the A-pillar or sail panel on axis, and do some absorption work in my door panels.. )
Will adjusting my tweets do anything with out A. passive xover taken out B. with an rca cord from headunit highs preout to amp?
Highs
HPF @ 2K, 12 db slope (assume phase is normal)
You could try playing around with this and the mids, raise it a little probably, since your mids are playing much higher than this right now.
Mids (bandpassed on hu)
HPF @ 50 hz, 12 db slope
With a 12dB slope, you are going to want to cross higher. Like, 100Hz, if your sub is at 80Hz w/24dB.
LPf @2.0k hz , 6 db slope
Sub
LPF @ 80hz 6db slope
Do you have anything higher than 6db? You should be able to find better, either on the HU or the amp. 6dB is trash for subs. If you are stuck with 6dB, cross at 50Hz, but I think you should be able to find a 24dB somewhere.
Another question at 6db slope.. say hpf @ 50 hz will the speaker be between little louder and twice as loud at 100 hz and 25 hz have the opposite effects?
I don't know what you are trying to say. Lol.
Bookmarks
