Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 84
Reload Thread: Alright, Boys (Noob uncertainties)
  1. #31
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    27
    3,488
    862 Post(s)
    Re: Alright, Boys (Noob uncertainties)
    What do you mean by signal wires? Signal wires usually are referred to as RCAs. If that's the case, I can't imagine why yours are in the fuse-box haha. So there must be a translation error there.
    You just make sure the thumb-drive is formatted properly (FAT32), and then copy the files overs. Most HU's have a "depth" limit for how many folders it can read deep. IE: Thumb drive>Music folder>Genre>Artist>Album>Track title
    Having it go that deep might cause problems. Most people don't do that anyways, but I thought I'd point it out. I have mine: Thumbdrive>Artist>Album>track
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  2. Likes AxT4430 liked this post
  3. #32
    AxT4430's Avatar
    AxT4430 is offline CarAudio.com Elite
    Aug 2012
    Akron, OH
    28
    848
    470 Post(s)
    Quote Originally Posted by TheUnderFighter View Post
    Sorry the turn on/off signal wire on the amps
  4. #33
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    28
    848
    470 Post(s)
    Its funny that you say it must be a translation.error,
    Im in college and im taking a philosophy of science class that focuses thus far on the philosophy of language. The problem within each interdisciplinary field has terms and translations like causality in physics compared to biology with reaction.or impulses in synaptic connections which generally mean the same thing, buts its hard to use physicist language to understand biology, so Logical Positivists tried to create an encyclopedia to unify and solve this issue
  5. Likes TheUnderFighter liked this post
  6. #34
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Quote Originally Posted by AxT4430 View Post
    Stop that.
    If you're going with the RS180, then if you can fit the RS tweeter, it's tough to beat for the money. Dayton Audio RS28F-4 1-1/8" Silk Dome Tweeter 275-140 Only problem is that it's a 4" tweeter. But, again, if you can fit it, it's supposed to be bomb.
    What's your budget, and where do you plan on crossing your subs/mids? What do you have for a substage?
    Also, fwiw, I prefer to set crossovers on the HU. Gives a set number, and much easier typically.
  7. Likes AxT4430 liked this post
  8. #35
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    28
    848
    470 Post(s)
    Quote Originally Posted by gckless View Post
    Stop that.
    Well if Im buying the the clarion or pr80s then it will be around 500, gives me 200 for drivers and tweeters. Plan on crossing my spl 15"(tss motor) at 110 with the drivers, or is that too much of a range for my future drivers (dayton rs180's) (110hz-1khz or something) and the tweeters play the remainder.. not sure of what slopes cause I dont understand that yet.
    Do you think the rs180's will have a good bass and clarity response if I seal off my doors in my honda civic like keephopealive?
  9. #36
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    28
    848
    470 Post(s)
    I have some mass storage devices, I should start utilizing those! btw, nice sig![/QUOTE]
    Quote Originally Posted by nismos14 View Post
    The two best units around right now are the Clarion CZ702 an the Pioneer DEH-80PRS, I would say the pioneer is a better bet because it provides you two USB inputs, however if I were to pick one up it would the CZ702.
    these are the options Im considering.
  10. #37
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Well if Im buying the the clarion or pr80s then it will be around 500, gives me 200 for drivers and tweeters. Plan on crossing my spl 15"(tss motor) at 110 with the drivers, or is that too much of a range for my comps (110hz-1khz or something) and the tweeters play the remainder.. not sure of what slopes cause I dont understand that yet.
    Cross that sub at 80. The RS180's should play down to 80 just fine, they just don't like to play too high for mids in a two way, no higher than 1.8k from what I have seen. But, that's not a big deal, just get a tweeter that will play that low. The RS tweeter I linked will do that perfectly.
  11. #38
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    28
    848
    470 Post(s)
    Got any help with this scalar(db) **** like 6db/12db/... slope ****?
  12. #39
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    Do some reading man. You may not be ready to go active.
    Subs/mids are usually at 24dB/octave, mids/tweets are basically what sounds good to you and the capabilities of your equipment.
  13. Likes ciaonzo liked this post
  14. #40
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    28
    848
    470 Post(s)
    I'm sure I'm not ready, I have till summer.. any sources of information for me to start at?
    Thankyou for all the interest so far
    And To everyone else, Im grateful! Ill keep this handy till summer then I'll likely ask again to clarify my purchases..
  15. #41
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    I don't have something specifically, but DIYMA. Just go start reading, start at the stickies, and anything that looks like it might apply to active, speaker selection, location, crossover, anything dude. There's probably a sticky or two here as well.
  16. #42
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    28
    848
    470 Post(s)
    Do i have to pay ?! lmao
    or
    Is that caco?
  17. #43
    gckless's Avatar
    Aug 2011
    San Antonio
    5,159
    6 Post(s)
    2218 Post(s)
    or
    Is that caco?
    Don't have to pay for either to participate in the forum. CACO requires an upgraded account to sell something, DIYMA requires 100 posts to sell I believe.
  18. Thanks AxT4430 thanked for this post
  19. #44
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    37
    6,792
    43 Post(s)
    1859 Post(s)
    I'm gonna get crucified for this but I think Bluetooth streaming music should definitely be tried if you have the chance. I use it every day on my CZ702 and with the heater blowing every second I'm driving I don't give a **** if I'm losing 2% of "detail" in my music, it still sounds good and I can rock out. I don't drive around listening to reference discs, I listen to bands that play loud.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
  20. Thanks AxT4430 thanked for this post
  21. #45
    nismos14's Avatar
    nismos14 is offline CarAudio.com Veteran
    Dec 2006
    Jersey
    36
    14,586
    273 Post(s)
    You likely loose more detail than that with just road noise, lol
    Car audio IS an addiction.
    C.A.A.A Member #1
    (Car Audio Addicts Anonymous)
    Refs http://www.caraudio.com/forums/buyer-seller-feedback/278560-nismos14-feedback-refs-thread.html
  1. Alright boys i ordered it.
    By Jacobman in forum General Discussion
    Last Post: 08-06-2007, 11:31 PM
  2. noob Please some advice?
    By trizzin4u in forum Subwoofers
    Last Post: 04-17-2002, 04:57 PM
  3. Alright Installers
    By RangerMan in forum Wiring, Electrical and Installation Help
    Last Post: 01-24-2002, 07:32 PM
  4. would this sound alright?
    By timmy23 in forum General Discussion
    Last Post: 12-16-2001, 10:30 PM
