+ Reply to Thread
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 84
Reload Thread: Alright, Boys (Noob uncertainties)
  1. #16
    AxT4430's Avatar
    AxT4430 is offline CarAudio.com Elite
    Aug 2012
    Akron, OH
    23
    849
    6 Post(s)
    Re: Alright, Boys (Noob uncertainties)
    Quote Originally Posted by TheUnderFighter View Post
    Well, the less Things in way of the speakers, the better. So if you can find an active HU, that has it's own adequate EQ, that'd be the best case scenario. Pioneer 80prs, Pioneer P99, Alpine 9887, Alpine 7998, Alpine 9813, Alpine 9855, Eclipse CD5030, Eclipse cd7100, Eclipse CD7200 Mkii. <<< All of those are great active HU's. Some older, some newer, some in between. I think the cheapest you'd find on there would probably be a really good deal on the Alpine 9855, starting at like $150. Most of those units go for between $200-$300. Some for much more.
    There's no such thing as an "active driver". Every driver is a driver. The drivers you have right now would work fine, you just remove the passive crossover. The benefit of running active, is you can piece together your own component set if you'd like. So if you were to piece together your own set, you'd be looking at "raw" drivers. Drivers sold separately and individually. Parts Express: the #1 source for audio, video & speaker building components and Madisound Speaker Components: distributor of loudspeaker drivers and parts for speaker builders. are good places to look for these DIY speakers. Most decent tweeters starting at $20-$30 a piece. And mids usually around $50 to be safe. Some can be cheaper. Many can be MUCH more expensive. Keep in mind, you don't NEED new speakers. You can still use the ones you currently have, you just remove the passive crossover.
    KISS method works best, it seems! Alright, thankyou so much for such a detailed response! Do you reccommend any tweeters if I pair them with dayton rs-180?
  2. #17
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    23
    849
    6 Post(s)
    Quote Originally Posted by nismos14 View Post
    Active crossovers have nothing to do with the equalizer. Most do have a pretty decent EQ built in.
    There isn't one, you need to understand slopes, and crossover settings and what drivers need what before you jump into that. Most active decks have generally the same settings, so it's not like one will be easier than the other.
    "Active drivers" are just passive speakers. They have no crossover built in, that's what the active head unit is for.
    Didn't you want to buy an "active" deck? Then why would you want active crossovers in addition to an active capable deck?
    Far too many out there you'd have to try to find as many reviews as you can on drivers to see.
    See above.
    Sorry, its obvious im confused.. I have a lot of learning with slopes and eq settings. Is there any sources on here that I will introduce me or just dive in?
  3. #18
    neo_styles's Avatar
    neo_styles is offline AKA Pop Twidget
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Anything that'll cross over down to 1.5-2K will work well with the RS180. Vifa VT25s have been known to work well with them, but like I said before, need to be installed on axis.
  4. #19
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    23
    849
    6 Post(s)
    As of right now, Im aiming towards going active with good gear, but keeping it simple.
    Ex. of what I mean:
    Buy active headunit like alpine 7998
    Buy dayton 6.5's and tweeters ( 2-way)
    and continue fixing up my doors and alternator issues.
  5. #20
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    23
    849
    6 Post(s)
    Quote Originally Posted by neo_styles View Post
    I've heard "on axis" many times but do you mean on axis with reference to my ears? on the same plane?
  6. #21
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    23
    849
    6 Post(s)
    what am I looking at for bluetooth or aux input as a necessary feature for my next active head unit? I use pandora as my source, convience bro's..
  7. #22
    nismos14's Avatar
    nismos14 is offline CarAudio.com Veteran
    Dec 2006
    Jersey
    32
    14,155
    3 Post(s)
    The two best units around right now are the Clarion CZ702 an the Pioneer DEH-80PRS, I would say the pioneer is a better bet because it provides you two USB inputs, however if I were to pick one up it would the CZ702.
    Car audio IS an addiction.
    C.A.A.A Member #1
    (Car Audio Addicts Anonymous)
    Refs http://www.caraudio.com/forums/buyer-seller-feedback/278560-nismos14-feedback-refs-thread.html
  8. #23
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    22
    3,405
    28 Post(s)
    On axis means pointed at your ears or face in a direct line iirc. Some people aim the speakers away from them to get a different, sometimes betters, sound. This is all subjective, and will be determined by you, since you will be listening. Dayton makes good stuff. I have the "Vifa Ring Radiator" tweets. Mine came without a mounting flange, and I put them in spheres. They do make them with a mounting flange as well, and that gives another way to mount them. e.g: Tweeter Spheres - pics and examples
    Those are not mine... but those are the same tweets I have, and that guy built the spheres for me too.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  9. #24
    neo_styles's Avatar
    Sep 2012
    Porter Ranch, CA
    27
    3,055
    41 Post(s)
    Quote Originally Posted by AxT4430 View Post
    Keep in mind that you'll lose some SQ using BT audio. I recommend the USB, personally, if you're not going to use CDs
  10. Thanks wickedwitt thanked for this post
  11. #25
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    23
    849
    6 Post(s)
    Im diggin that clarion, dont 80prs have problems with the pico fuse?
    ---------- Post added at 08:39 PM ---------- Previous post was at 08:38 PM ----------
    I have some mass storage devices, I should start utilizing those! btw, nice sig!
  12. #26
    wickedwitt's Avatar
    wickedwitt is offline CarAudio.com Veteran
    May 2010
    Abilene, TX
    2,932
    34 Post(s)
    ch
    Whats better a quality dedicated equalizer or an active headunit with eq and parameter settings/ eq bands?
    @neo_styles ; bitch get in here
    There isn't a better quality active HU, unless you want to drop $1,000+
    EDIT: Just install it properly and you won't have pico fuse problems. It is also easily fixed if it does blow and you end up with noise.
    Stupid Loud.
  13. Likes AxT4430 liked this post
  14. #27
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    23
    849
    6 Post(s)
    Do you know if this fellow would make another set, if so how much were yours?
  15. #28
    Mar 2011
    22
    3,405
    28 Post(s)
    Absolutely. I believe he's doing something around $40 a set. You could always PM him directly to find out though, he's exceptionally helpful. If you get different tweeters, you may have to have them shipped to him so he can make the spheres. Those are details you guys could sort out.
    The Pico fuse isn't typically an issue if you install correctly. If it becomes an issue, it can be fixed.
    And I would highly recommend NOT streaming through BT Audio if you want it to sound good. Best bet is either CD's, or USB devices.
  16. #29
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    23
    849
    6 Post(s)
    trivial question but where do you guys connect your signal wires in your cars? I have a 02 honda civic ( no eld switch yet) and I have it connect to a acc radio fuse underneath my steering wheel fuse box.. but i keep disconnecting it every few months..
  17. #30
    AxT4430's Avatar
    Aug 2012
    Akron, OH
    23
    849
    6 Post(s)
    gotcha, I have to read up on, after uploading them from youtube using our own music program in the dome, putting them on my thumb drive to access, or is it a simply drag and drop ordeal? I have a pc, fyi.
+ Reply to Thread
  1. Alright boys i ordered it.
    By Jacobman in forum General Discussion
    Last Post: 08-06-2007, 11:31 PM
  2. noob Please some advice?
    By trizzin4u in forum Subwoofers
    Last Post: 04-17-2002, 04:57 PM
  3. Alright Installers
    By RangerMan in forum Wiring, Electrical and Installation Help
    Last Post: 01-24-2002, 07:32 PM
  4. would this sound alright?
    By timmy23 in forum General Discussion
    Last Post: 12-16-2001, 10:30 PM
