Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Reload Thread: What double DIN head unit to buy?
  1. #16
    Sonic.'s Avatar
    Sonic. is offline CarAudio.com Elite
    Jul 2012
    Toronto
    570
    122 Post(s)
    Re: What double DIN head unit to buy?
    Quote Originally Posted by dragnix View Post
    really? I heard ppl normally prefer steeper slopes for the midbass, but everyone is different
    Well most time you can get away with the shallower slope at the mid/low end, but it's more difficult for the tweets, especially, what's available today in the car audio market. Most 2 way active front stage requires a large format tweeter, while it takes alot of mod to do that. So, a small format is used with a steeper slope. But all in all, it's subjective to the drivers chosen, and most take the easy way.
  2. #17
    dragnix's Avatar
    dragnix is offline LXIX
    Dec 2006
    Socal cuz i'm So cool
    19,730
    682 Post(s)
    Quote Originally Posted by Sonic. View Post
    The way I see it is that on the lower end you need a steeper slope as the octaves get a lot closer together. An octave down from 80hz is 40hz, a lot closer than 4khz and 8khz. So when it's cut at 18db/slope it is much more beneficial (as I see it) at the lower end since it doesn't allow for overlapping of the mids and subs and sometimes the tweets and mids.
  3. #18
    Sonic.'s Avatar
    Jul 2012
    Toronto
    570
    122 Post(s)
    I see your point, makes sense.
  4. #19
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    The high end double DINs all have a full face that doesn't leave room for an exposed CD slot. For a budget of $400-500 I would just pair the head unit with a 4-channel amp that has a bandpass crossover built in. Most amps are going to limit that to a 12 dB/octave slope but it's not that big of a deal for a budget active setup. Many passive crossovers use a 12 dB slope.
    edit: Factory XM radio is different from aftermarket. An "XM Ready" receiver will have a separate box required to get XM radio working. A new antenna is provided. Sometimes you can stick the antenna to the top of the radio and it will get signal through the dash and the windshield. The best reception comes from putting the antenna on the roof.
    The 2012 Pioneer AVH-P3400BH has most of the features you want. The new model replacing that is the AVH-X3500BHS. I don't know if it's shipping yet.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
  5. #20
    smgreen20's Avatar
    smgreen20 is offline phoenixphorum-com
    Apr 2005
    Lafayette,IN
    41
    1,175
    35 Post(s)
    Quote Originally Posted by mikeb618 View Post
    The SD card slot is nothing i care about. I have 16g of music on my phone so i don't really need it or want to mess with loading more music onto something else.
    FYI, the SD is for the Navigation. I am not sure though, if you could take it out and put in one with music and it play??????
    My install
    http://phoenixphorum.com/viewtopic.php?f=10&t=16998
  6. #21
    mikeb618's Avatar
    mikeb618 is offline RANDOM DUDE
    Mar 2011
    Rado Il
    35
    12 Post(s)
    Quote Originally Posted by trumpet View Post
    So, is it not possible to use the factory XM antenna? Seems like there would be an adapter to make it work.
    I have realized that getting a deck that allows me to run a active system is not happening and i am fine with that. I just thought that if i was going to buy a deck i should try to get all that appeal to me.
    Does the pioneer AVH-P3400BH have a good pandora app?
    Thanks to everyone for the help!
  7. #22
    mylows10's Avatar
    mylows10 is offline B2,singer,ampere rep mylows10 is a Supporting Member of the forum!
    mylows10 is a Supporting Vendor of the forum!
    Sep 2009
    monterey , ca
    54
    22,434
    141 Post(s)
    1 Thread(s)
    6011 Post(s)
    all the pioneer decks work really well with pandora , the 3400 does have a small screen tho
    pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
    4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
    B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
    NOR CAL DB DRAG JUDGE
    http://www.dcsoundlab.com
  1. Advice for buying double din head unit
    By n3gr0n in forum Head Units
    Last Post: 12-02-2012, 11:52 PM
  2. what brand of head unit to use
    By deadilus in forum Head Units
    Last Post: 12-09-2004, 09:21 PM
  3. Looking for Double Din head unit
    By Croat23 in forum General Discussion
    Last Post: 10-22-2002, 03:19 AM
  4. ford focus double-din head unit
    By markf8 in forum Wiring, Electrical and Installation Help
    Last Post: 06-30-2002, 11:42 AM
