+ Reply to Thread
Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 71 of 71
Reload Thread: ok. this is really pissing me off. Pioneer 80prs
  1. #61
    groundpound4200's Avatar
    groundpound4200 is offline Da fuq did I just read?
    Nov 2007
    Mankato, MN
    27
    5,260
    4 Post(s)
    Re: ok. this is really pissing me off. Pioneer 80prs
    Quote Originally Posted by jockhater2 View Post
    Yeah. Thankfully someone answered that. I didn't think about the HU's internal amp.
    I don't even play the stereo now.
    Can't wait to finish it all up the right way.
    ---------- Post added at 01:47 PM ---------- Previous post was at 01:47 PM ----------
    hey. my camry's factory HU doesn't clip either.
    can you link to me some single Dins that cost $500+
    I couldn't find any
    Stage 4 | Pioneer Electronics USA
    2007 Honda Pilot 2008 Nissan Maxima
    2 RD D9s strapped @ 1 ohm Sundown SAZ-1500D V.3
    2 Sundown Nightshade V.2s 2 10" Atomic APX
    Sundown SAX-125.2 x 2 Sundown SAX-100.4
    Sundown NeoPro 6.5"s, JL ZR Tweets Sundown NeoPros
    RIP Taylor aka NewAgeKing, you are missed!
  2. #62
    SourDeez's Avatar
    SourDeez is offline CarAudio.com Veteran
    Apr 2007
    Fuqy u
    4,134
    62 Post(s)
    Quote Originally Posted by groundpound4200 View Post
    owned
    Headunit - Stock cassette player - Pioneer P9400
    Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
    Rear stage - Deleted (stolen) - Deleted
    Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
    Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
    Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
  3. #63
    jockhater2's Avatar
    jockhater2 is offline CarAudio.com Veteran
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    holy crap. Well of course it doesn't clip. It states it doesn't have an internal amplifier. But wowzer. That is expensive.
    what makes it just destroy the 80prs? the 31 band eq? along with the 4 24 converters and the 32 bit?
    Head Unit Pioneer P99RS
    3 Runs of 1/0 OFC Power and 3 Runs of 1/0 OFC Ground
    1 XS Power D3400 & 2 XS Power XP3000 with Copper Bus Bars
    380 Amp & 320 Amp Iraggi Alternators(One is a chevy case, the other ford)
    RD 7500.1 running 2 12 inch Ascendant Audio Mayhems (might go up for sale)
    Tuned to 36 hertz. About 4.5 cubic feet, 8" Aeroport (made by dbeez)
    Audison LRx 6.9k on Morel MDT-29, RS100-4 & RS225-8 Daytons
    Alex Jones www.infowars.com Endgame, Obama Deception, Truth Rising,
    Fluoride in the water, poison in vaccines, chemical trails in the skyglobal
    elite banks run our government towards a one world global government.
  4. #64
    SourDeez's Avatar
    Apr 2007
    Fuqy u
    4,134
    62 Post(s)
    Clipping
  5. #65
    gckless's Avatar
    gckless is offline CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,375
    23 Post(s)
    Those are the main reasons it sounds so good, plus it is 3 way plus sub active capable and looks sexy. I'm sure there are other things, but I have never played with one nor really looked into one. It's too expensive for me.
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  6. #66
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    Quote Originally Posted by gckless View Post
    x2 1200 is definitely breaking the bank.
    isn't the 80prs a 3 way?
    and what is sub active capabilities?
  7. #67
    gckless's Avatar
    Aug 2011
    San Antonio
    3,375
    23 Post(s)
    The 80prs is 3 way, high and low front stage plus sub. The p99rs is 4 way, high, mid, and low front stage plus sub. Sub active is the same as any other speaker, I just kinda said it weird in that post.
  8. #68
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    I thought there isn't much to tweak on subs since the signal is mono.
    Hmmm. The HU being 3 way doesn't really mad anyways correct. Because once you run it active. Aren't you relying on the amplifiers crossovers then? The audison has an intense amount of crossovers.
  9. #69
    gckless's Avatar
    Aug 2011
    San Antonio
    3,375
    23 Post(s)
    Active vs. passive is concerning the crossovers. Active uses some sort of digital processing, passive is done mechanically with capacitors, resistors, etc. Almost all subs are crossed actively, don't think I have ever actually personally seen passive subs that actually use a crossover, though I'm sure it happens in home audio. Even though the sub signal is mono, you can still adjust a lot, such as levels, crossover points and slope, time alignment, things like that.
    The HU being 4 way does matter very much. It allows you to set your crossover points and slopes very accurately on the HU, and doesn't require external processing. Using the crossovers on an amp, if they are there, is usually hard to do because they only have rotational knobs that aren't detented. To get 3 way fronts otherwise, you would need a processor that breaks that signal down and does the same thing. I guess you could run a full range signal out of any HU, split it to 3 channels of an amp, and use the crossovers there as well, but I don't think I have seen that.
    When you use the crossovers on a HU, you generally don't use them on the amp, only to get a steeper rolloff at a certain frequency. Not sure how @keep_hope_alive is going to have you set it up, but my guess is you will be using the crossovers on the HU and running the amp as full range. That's how my 80prs is set up at least.
    And of course, he will most likely know much more than what I just wrote, and probably point out that I am incorrect somewhere. This stuff gets confusing sometimes, and I'll be the first to admit I don't know everything.
  10. #70
    keep_hope_alive's Avatar
    keep_hope_alive is online now Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,014
    28
    124 Post(s)
    cliff notes?
    when it comes to setting up the HU and amp, I'll just have him call me so we can talk through everything.
    the Audison crossovers are much better than the Pioneer crossovers - so we'll use them as much as we can.
    the main reason for the HU is T/A.
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
  11. #71
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    cliff notes?
    I was thinking that too. Because the audison has a lot of cross over settings.
    Yeah. That will make it much easier.
+ Reply to Thread
  1. this is really getting me annoyed
    By thericanballer in forum Speakers
    Last Post: 12-29-2009, 11:55 AM
  2. OK, this is pissing me off!
    By endofdays89 in forum General Discussion
    Last Post: 09-03-2008, 09:13 AM
  3. This is the kinda ***** that pisses me off.
    By frozenfire89 in forum General Discussion
    Last Post: 02-16-2004, 12:05 AM
