Stupid Loud.
Head Unit Pioneer P99RS
3 Runs of 1/0 OFC Power and 3 Runs of 1/0 OFC Ground
1 XS Power D3400 & 2 XS Power XP3000 with Copper Bus Bars
380 Amp & 320 Amp Iraggi Alternators(One is a chevy case, the other ford)
RD 7500.1 running 2 12 inch Ascendant Audio Mayhems (might go up for sale)
Tuned to 36 hertz. About 4.5 cubic feet, 8" Aeroport (made by dbeez)
Audison LRx 6.9k on Morel MDT-29, RS100-4 & RS225-8 Daytons
Alex Jones www.infowars.com Endgame, Obama Deception, Truth Rising,
Fluoride in the water, poison in vaccines, chemical trails in the skyglobal
elite banks run our government towards a one world global government.
Man, you should really figure out how to set the crossovers properly. It's only going to get more confusing once you switch over to network mode. You are going active once you get the amp you said right? Play with that bish. Turn all the damn knobs and change the settings, see what each one does. Figure that thing out man. You can just go back and reset it if you don't like what you did.
Its clipping you retard
Headunit - Stock cassette player - Pioneer P9400
Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
Rear stage - Deleted (stolen) - Deleted
Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
[QUOTE=jockhater2;8226097]keep_hope_alive is helping me set up the audison and with going active
---------- Post added at 02:41 PM ---------- Previous post was at 02:41 PM ----------
No doubt he'll be able to take care of you. With that, I consider this thread closed
Edit: Wtf just happened with teh quotz???
my 80prs clipped at 54 for the sub and 60 for front, rear. also when i pluged the rca strait to the dd1 it didnt show no clipping for front rear. but when i tested it threw the amp it showed clipping at 60.
2003 JEEP Grand Cherokee LTD
HU- pioneer 80prs
Front Stage- B2 ES 6.1I
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
Subs- Tantric HDD 12's
box - 6^3 33hz
[QUOTE=gckless;8226101] I have no idea. what did happen?
yeah I have never ran a mids/high amp before. so my front stage has ALWAYS BEEN GARBAGE. It is time to camrify (camry) it.
keep hope alive already said he would help me with setting up the whole thing. so everything will be done correctly.
and keep the volume at 52 fixed the problem. it was obviously that HU clipping. I don't know why I didn't realize it. Probably because my last kenwood sounded fine all the way up.
---------- Post added at 02:48 PM ---------- Previous post was at 02:47 PM ----------
I will have to O-scope it then to be more accurate.
Jock, your first quote of sour is the problem w/ all the quotes. You are missing the opening "[" in the quote closure.
Sour, while your first post did contribute that his problem was clipping, every other post since then hasn't been on the subject whatsoever. Think you can stay on topic? This could be a decent thread for 1. People w/ 80PRS and 2. Deck power mids that don't understand the clipping difference in HU power vs. amped power.
Stupid Loud.
Bookmarks
