+ Reply to Thread
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 71
Reload Thread: ok. this is really pissing me off. Pioneer 80prs
  1. #16
    jockhater2's Avatar
    jockhater2 is offline CarAudio.com Veteran
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    Re: ok. this is really pissing me off. Pioneer 80prs
    Quote Originally Posted by gckless View Post
    How did you test them? I've seen more than one person test them with an O-scope and report they in fact clip. I would not believe any HU under $1k doesn't clip at max volume.
    distortion detector. using the 0db 40hrtz and 1khz track.
    I can throw an O-scope on it to double check
    ---------- Post added at 06:46 PM ---------- Previous post was at 06:45 PM ----------
    Quote Originally Posted by bhsdriller View Post
    try this...around 80hz
    the front/rear HPF is at 200hertz and it still doesn't help
    even if I keep the volume down they sound like they are playing too much bass
    ---------- Post added at 06:46 PM ---------- Previous post was at 06:46 PM ----------
    Quote Originally Posted by whitedragon551 View Post
    There are a few Alpine headunits that dont clip. The 9887 included. Its not highest end by any means, but its definitely not the lowest end either.
    isn't the 80prs the highest single din you can get?
    Head Unit Pioneer P99RS
    3 Runs of 1/0 OFC Power and 3 Runs of 1/0 OFC Ground
    1 XS Power D3400 & 2 XS Power XP3000 with Copper Bus Bars
    380 Amp & 320 Amp Iraggi Alternators(One is a chevy case, the other ford)
    RD 7500.1 running 2 12 inch Ascendant Audio Mayhems (might go up for sale)
    Tuned to 36 hertz. About 4.5 cubic feet, 8" Aeroport (made by dbeez)
    Audison LRx 6.9k on Morel MDT-29, RS100-4 & RS225-8 Daytons
    Alex Jones www.infowars.com Endgame, Obama Deception, Truth Rising,
    Fluoride in the water, poison in vaccines, chemical trails in the skyglobal
    elite banks run our government towards a one world global government.
  2. #17
    Iosias's Avatar
    Iosias is offline Senior VIP Member
    May 2012
    United States
    408
    5 Post(s)
    Ive tested the 80prs to 60 without clipping.
    Refs # Tallc, CleaRSkieS, Roth, Goindef154, Kangaroux, tv559
  3. #18
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,456
    4 Post(s)
    Quote Originally Posted by jockhater2 View Post
    you have the manual?
    I assume you're running it in standard mode and not active
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
  4. #19
    gckless's Avatar
    gckless is online now CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,375
    23 Post(s)
    Quote Originally Posted by winkychevelle View Post
    yea i dont know how you tested the rcas on the deck but they do clip at 52-55. and go to front crossover setting 2 and turn the volume knob or turn the bone shape knob and set the hpf to 80hz same for the rears.
    ^^Should be this. Are you in network or standard mode? Either way, it's called crossover 2 or network 2 or something like that, may even be network 1 or 3, I don't know for sure without being in front of mine. There will be frequencies you can set front, rear, and sub crossover. I think choices are 63Hz, 80Hz, 100Hz, 125Hz, and so on up to 200Hz. You just must have missed it in the manual. It's in there, I promise.
    i didn't read the installation.
    i just read the full
    Edit: So many posts in the last minute! Something else could be wrong if you are getting substantial bass even with it set to 200Hz. Compare it to off, are they the same?
    Quote Originally Posted by ducatipaso View Post
    To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
    Quote Originally Posted by benbenondatrack View Post
    stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
  5. #20
    nismos14's Avatar
    nismos14 is offline CarAudio.com Veteran
    Dec 2006
    Jersey
    32
    14,155
    3 Post(s)
    Educate yourself.
    Car audio IS an addiction.
    C.A.A.A Member #1
    (Car Audio Addicts Anonymous)
    Refs http://www.caraudio.com/forums/buyer-seller-feedback/278560-nismos14-feedback-refs-thread.html
  6. #21
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    yes. until the audison lrx6.9k goes in
  7. #22
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    its sounds like my substage when the HPF is off. and if i turn the octave down.
    ---------- Post added at 06:54 PM ---------- Previous post was at 06:53 PM ----------
    Quote Originally Posted by nismos14 View Post
    Educate yourself.
    go fvck yourself douch3
  8. Dislikes nismos14 disliked this post
  9. #23
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    im going down to a audio shop tomorrow.
    Looking to have them make kickpods for my new Daytons to redo my crappy front stage.
    I'll have them O-scope the RCA.s
    Because when I did them with the DD1. they didn't distort.
    and neither did my previous kenwood x895. that HU sounded awesome.
  10. #24
    vaiboy's Avatar
    vaiboy is online now Senior VIP Member
    Sep 2006
    Phoenix, AZ
    241
    1 Post(s)
    1st off. I can't wait to get my audison in so i can quit using the HU to power my front stage.
    2nd. can't wait to ditch my coaxials.
    ok. my front stage won't stop playing bass and distorting when I turn the deck up to 62.
    I set the octave to 12 because it seems to let the least amount of bass.
    the high pass filters are all the way up on the front and rear.
    and still the front stage speakers sound like they are going to blow.
    so i messed with the equalizer.
    I turned all frequency's from 20hz-315 to -6db.
    But now..obviously the subs are loud because of that.
    How can I get the front stage to please stop playing bass.
    You are running the front stage off of the internal amp, even if there is no clipping/distortion at the preouts, there will be loads of distortion from the tiny internal amplifier. If your sub stage is overpowering the highs, turn down the sub stage to balance it out until you get a properly amped front stage.
  11. Thanks jockhater2 thanked for this post
  12. #25
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    Quote Originally Posted by vaiboy View Post
    wow. thank God. an answer that makes sense.
    That has to be it. I didn't even think about it. The internal amp on the HU is clipping.
    Because I tested the RCA's and they do not clip.
    But that wouldn't matter since I am only using the SW RCA output.
    Well then. Until I get my audison in. I will just have to keep the volume down.
    THANK YOU!
    Perfect answer!
  13. #26
    gckless's Avatar
    Aug 2011
    San Antonio
    3,375
    23 Post(s)
    Oh man, totally missed the part where you were using internal amp. That's definitely why you are getting distortion. Doesnt explain why you are getting a lot of bass though. When you do start using an amp, don't use past 58 for your max. It will be dirty.
  14. #27
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    I will retest the RCA outputs.
    But when I tested all 3 of them the first time. The RCA's did not clip. But I will definitely double check.
  15. #28
    nismos14's Avatar
    Dec 2006
    Jersey
    32
    14,155
    3 Post(s)
    My problem is that you're asking very basic questions and you're buying very high end equipment. You can learn most of this on your own.
    C.A.A.A Member #1
  16. #29
    jockhater2's Avatar
    Sep 2011
    Saukville, WI
    2,598
    34 Post(s)
    never said i was a sexpert.
    and didn't even think about the HU's internal amp. completely forgot about it.
    you must hate camry's bro
  17. #30
    wickedwitt's Avatar
    wickedwitt is offline CarAudio.com Veteran
    May 2010
    Abilene, TX
    2,932
    34 Post(s)
    Set the HPF and LPF. The slope is just how fast those frequencies roll off.
    There should be a HPF/LPF for lows, mids, highs. And depending on how you have it set up. Sometimes you can set your left and right equal or they can be independent. If they are independent it will be a HPF/LPF/Slope for lows, mids, and highs for the left side and HPF/LPF/Slope for lows, mids, and highs for the right side.
    I bet this is the issue. Every deck is different btw. My 80PRS has 0 clipping at 61, but a decent amount at 62. On all 3 pre-outs.
    I did the exact opposite when I got mine, set my xover points, but forgot to set the slope. Same effect.
    Stupid Loud.
+ Reply to Thread
  1. this is really getting me annoyed
    By thericanballer in forum Speakers
    Last Post: 12-29-2009, 11:55 AM
  2. OK, this is pissing me off!
    By endofdays89 in forum General Discussion
    Last Post: 09-03-2008, 09:13 AM
  3. This is the kinda ***** that pisses me off.
    By frozenfire89 in forum General Discussion
    Last Post: 02-16-2004, 12:05 AM
