Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
Re: Lightening port on apple products
Originally Posted by
itsblown
have you done back to back comparisons with a c.d.? ive always wondered this any idea what the transfer rate is? and the sound quality via blue tooth probably varies strongly depending on the head unit im guesing
SourDeez
It depends on the quality of the file being played.
I play 320kbps thru my iPhone/iPod via USB cable. Lightning should be the same.
Same as CD
^^^This. Lightning is only the connector used on the iPhone, it's still via a USB interface. I am not using bluetooth, and would only ever use that for audio as a last resort. Although I guess I don't know what the transfer speeds/throughputs of bluetooth really are. Never really cared. It would be good to look into if you planned on using that.
ducatipaso
To say that 8inch, 10inch and even 12inch subs are for girls is just not true. 15inch subs can't play fast beats, they take more power and that taxes the vehicles electrical system. You will wake up and "hear" then see the light at the end of the tunnel and it will be 3 10's pounding so hard you wont even open your trunk or turn your system on because you 15's will sound sloppy & weak.
benbenondatrack
stfu lesbo.why are you worried about me so much? you must want to date me ya little cookie monster but i dont even like sweets. your just a cup full of ice, dirt dead nasty azz ice...without the water.
gckless
Its compressed
Headunit - Stock cassette player -
Pioneer P9400 Front Stage - Pyle 8 inch subs (1000 watt peak!!) -
Polk DB6.5 (about to be CDT 6.5s) Rear stage - Deleted (stolen) -
Deleted Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) -
Two SA12's built by Corey Sub amp - Pyle 8000w peak!! (spl edition) -
AQ2200 Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable -
Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
SourDeez
Its compressed
Yeah, but to what? Why would it compress the signal if the throughput was high enough?
ducatipaso
benbenondatrack
By Nikuk in forum Enclosure Design & Construction Help
Last Post: 08-15-2004, 08:01 PM
By mrray13 in forum Enclosure Design & Construction Help
Last Post: 04-11-2004, 11:34 AM
By maniackilla in forum General Discussion
Last Post: 09-29-2003, 10:32 PM
By S(Q)PL in forum Enclosure Design & Construction Help
Last Post: 06-22-2003, 11:01 PM
By mgaidica in forum General Discussion
Last Post: 03-31-2003, 11:09 PM
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
