Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 39
Reload Thread: iPhone 5 Thread
  1. #16
    tc300's Avatar
    tc300 is offline CarAudio.com Veteran
    Mar 2007
    springfield,ill
    2,193
    2 Post(s)
    Re: iPhone 5 Thread
    Quote Originally Posted by clickclickw00t View Post
    You do know that when you use the 3.5mm headphone jack you're using the iPod's amp and you're distorting the output because, in effect, it's being amplified 2 times, once by the ipod, and then by the headunit. When you connect your ipod/iphone device straight to your headunit via a USB cable, the head unit is doing the Digital to Analog conversion and you have better audio quality?
    Ive used my phone on my buddys deck via usb... Those same songs dont sound as good as in my car with 3.5 jack.. Tho my system is better tuned also.. :-)
    MODS
  2. #17
    rfmayhem's Avatar
    rfmayhem is offline audio4life
    May 2012
    near your
    462
    3 Post(s)
    Re: iPhone 5 Thread
    i really hope apple have some type of trading program for all the people who brought all those docking station/accessory etc. that was a bad idea changing that port now all the companies out there that support apple device got to switch up SMH
  3. Likes tc300 liked this post
  4. #18
    West's Avatar
    West is offline Banned
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Re: iPhone 5 Thread
    Quote Originally Posted by tc300 View Post
    I think you can get some more noise from the usb low level line. I don't notice the noise with the 3.5mm
  5. #19
    armykyle1's Avatar
    armykyle1 is offline armykyle1
    Feb 2009
    Gulfcoast MS
    245
    2 Post(s)
    Re: iPhone 5 Thread
    another way for apple to soak up America's money and sue samsung.
    I'm not surprised at all
    Build
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/550173-amykyle1s-ever-changing-build.html
    Youtube
    http://www.youtube.com/user/armykyle1
  6. #20
    splwj47's Avatar
    splwj47 is offline CarAudio.com Veteran
    Aug 2011
    Great White North
    24
    2,568
    29 Post(s)
    Re: iPhone 5 Thread
    Quote Originally Posted by armykyle1 View Post
    so what did u all win from the ia contest?
    2003 JEEP Grand Cherokee LTD
    HU- pioneer 80prs
    Front Stage- B2 ES 6.1I
    FS Amp- B2 Quattro
    Sub Amp-B2 Zero1
    Subs- Tantric HDD 12's
    box - 6^3 33hz
  7. #21
    tc300's Avatar
    Mar 2007
    springfield,ill
    2,193
    2 Post(s)
    Re: iPhone 5 Thread
    Lmao! Glad we bought some apple stock back when the first iphone came out!!! :-)
    Can we say CHING CHING!!!
    MODS
  8. #22
    clickclickw00t's Avatar
    clickclickw00t is offline Member
    Sep 2012
    United States
    111
    Re: iPhone 5 Thread
    Quote Originally Posted by West View Post
    I'm not even sending low-level line over the USB, the MP3 file is essentially being read digitally by the headunit, and then converted on the headunit to play on the audio system (if I'm not mistaken?).
  9. #23
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Re: iPhone 5 Thread
    I can hear inteference from the usb... don't know if its from the cord or from the crappy iphone... lol
  10. #24
    Sep 2012
    United States
    111
    Re: iPhone 5 Thread
    It all also depends on the chord you have. When I first got my Pioneer P4400BH, I got a crappy e-bay cable and I had interference too, and I couldn't do streaming video to the headunit.
    Then I shelled out $70 for a genuine Pioneer iPod USB connector, and haven't had a single problem since...
  11. #25
    West's Avatar
    Jan 2012
    Oliver Springs, TN
    3,705
    73 Post(s)
    Re: iPhone 5 Thread
    I am using the cable that came packaged with my p99rs... might be my iphone its seen a few trips to the floor
  12. #26
    gckless's Avatar
    gckless is online now CarAudio.com Veteran
    Aug 2011
    San Antonio
    3,387
    23 Post(s)
    Re: iPhone 5 Thread
    USB vs. 3.5mm, in theory and on a smaller scale in practice, should be no contest. I'm no audio professor, but I do work with telecommunications every day, and I can say from experience that the longer you can keep a signal digital, the better that signal will stay true to it's original form. Once you convert that file to analog at the iPod to transmit over the 3.5mm, it starts to hit some degredation. I know I can notice a difference in USB vs. 3.5mm, in low vs. high bit rate MP3's, and in MP3's vs. a lossless signal or CD's. If you can't, why on earth would you continue to spend money to make your already dirty source try to sound better? I will continue to use digital, USB in this case. Yeah there's way more that comes into play here, but simply put, USB should always win in a contest vs. 3.5mm, except that 3.5mm you can plug into any device.
    I just hope those lightning USB cables come out soon, and that these firmwares on the HU's all work with the new hardware/software.
  13. #27
    d77543020's Avatar
    d77543020 is offline CarAudio.com Elite
    Dec 2005
    stockton ca
    1,894
    5 Post(s)
    Re: iPhone 5 Thread
    i always hear this and hostley i cant hear that much of a diffrence between the headphone jack and dock conecter
  14. #28
    wErd's Avatar
    wErd is offline Maker of All Good Threads
    Nov 2003
    usa
    5,491
    1 Post(s)
    Re: iPhone 5 Thread
    I'm sure most of you have seen the new iPhone 5 and Apple's newest iTouch releases.
    There's just one problem for all of us that use an ipod cable to connect to head units:
    THIS UNIT HAS A LIGHTING PORT!!!!
    Yes, that's right, as can be seen here:
    iPhone - Buy iPhone 5 with Free Shipping - Apple Store (U.S.)
    The port is different. This is something everyone with a headunit that uses an ipod cable are going to have to deal with. Just more $$$ for Apple via accessories everyone will be. I'm sure there will be bulky adapters, but I'm really not looking forward to how ugly that will make my interior.
    Let's hear some thoughts on this!
    Get a headunit with a USB port. Most nowadays have that instead of a dedicated iPhone cable.
    refs: viveet, dvrmstrng,velobard,pickup1,rumblebee2
  15. #29
    Sep 2012
    United States
    111
    Re: iPhone 5 Thread
    Quote Originally Posted by wErd View Post
    My headunit does have a USB port, however my iphone serves as my hub of digital everything:
    music
    movies
    pictures
    GPS
    address/phonebook/bluetooth calling
    Pandora
  16. #30
    Sep 2012
    United States
    111
    Re: iPhone 5 Thread
    Quote Originally Posted by gckless View Post
    And yes, you're completely right. Theory, and slightly in practice, USB wins over 3.5mm by default. USB allows the head unit to receieve the digital file, convert it to analog sound, and send it out through your speakers. On the other hand, the 3.5mm jack is converted from digital to analog by the ipod/iphone dac (which *****), and then it's amplified through the 3.5mm jack, and then amplified AGAIN through the head unit.
  1. Check this out...A hell of a thread...
    By RangerMan in forum Subwoofers
    Last Post: 07-30-2002, 09:54 PM
  2. Guys I really need help with my other thread..
    By adamawayfrommpa in forum Subwoofers
    Last Post: 07-15-2002, 11:44 PM
  3. Official JBL BP 1200.1 thread
    By JTz62 in forum Amplifiers
    Last Post: 06-26-2002, 11:48 PM
  4. 1000 Thread
    By Ricky Nichols in forum General Discussion
    Last Post: 04-18-2002, 02:15 PM
