Results 1 to 9 of 9
Reload Thread: 2007 Pathfinder, AVH-P8400BH Install Help!
    NickCR's Avatar
    NickCR is offline Stereo Moron
    Sep 2005
    San Jose, CR
    31
    77
    Hello All,
    So I finally got my deck and it's burning a hole on my kitchen table.
    I have watched a few instructional videos on YouTube for getting the radio out. That really doesn't seem very difficult.
    The problem I'm having is decided which Harness to use. I bought two brands. Metra and a Scoshe. There is one wire in different positions between the two.
    Metra has a orange/black wire (next to the yellow, below orange) and the Scoshe has a black (on the edge, below red). If both the orange/blak and black wires were present they would be ... Yellow, Orange/Black, Black.
    The wiring part for the speakers is pretty easy. No sweat there.
    Also I got the $20 parking break pulse thing, which I will install between the HU and the OEM Harness. The parking brake signal is green and marked, easy enough.
    Now the fun part starts. I also bought a AXXESS ASWC (Steering Wheel Control). I want to install that but the wires are really not clear to me at all. The interface has 10 cables. Here is a copy paste from their doc for my car.
    Vehicle Information
    Resistance Type Control System YES
    Reference Ground Wire Color BLUE
    Reference Ground Polarity (-)
    Reference Ground Location RADIO HARNESS
    Reference Ground Pin # 3
    Control Wire 1 Wire Color RED
    Control Wire 1 Polarity (-)
    Control Wire 1 Location RADIO HARNESS
    Control Wire 1 Pin # 4
    Control Wire 2 Wire Color GRAY
    Control Wire 2 Polarity (-)
    Control Wire 2 Location RADIO HARNESS
    Control Wire 2 Pin # 12
    Then they link to this doc. Still not sure which cable I'm supposed to connect where on the harness. Or when I pull out the stock radio there will be a 3rd wiring harness for SWC?
    http://contentdocs.installernet.com/...icle/10979.pdf
    On the 2007 Pathfinder should the radio go in without any dashboard modification? Do I just screw into the stock braket?
    One last thing, the microphone that comes with the unit, how do I run it up next to the mirror? Up the pilar? How do I get the cable there? Behind the glovebox? Does the pilar just pop off or is there a trick to getting it off?
    Thanks in advance!
    Nick
    Costa Rica - 2007 Nissan Pathfinder LE
    trumpet's Avatar
    trumpet is online now Supporting Vendor trumpet is a Supporting Member of the forum!
    trumpet is a Supporting Vendor of the forum!
    Jan 2011
    Langdon, ND
    32
    1,938
    48 Post(s)
    Re: 2007 Pathfinder, AVH-P8400BH Install Help!
    Quote Originally Posted by NickCR View Post
    Vehicle Information
    For the wires that say "connect to pin #X on the wire harness" you need to tap into a wire coming out of the factory radio harness. You can do this with 3M Scotchlok connectors(not the greatest but this is what they're made for) or you can cut the wire a couple inches from the harness connector and splice in with small butt connectors, OR you can solder and heat shrink wrap the splices. If none of this makes sense you might want to pay a shop to install this.
    Small town service, family owned and operated.
    Click for my CDT Audio dealer store, Clarion, JBL, Precision Power, Massive Audio, Diamond Audio, Metra, and much more
    my system: Clarion CX501, JBL MS-8, Massive Audio NX4, Xtant 1.1i, CDT DRT-26A, ES-020, ES-6MO, CL-62SL, JBL MS BassPro SQ
    NickCR's Avatar
    Sep 2005
    San Jose, CR
    31
    77
    Quote Originally Posted by trumpet View Post
    Thanks for your response!
    I live in Costa Rica and they are not used to working with this kind of stuff. I have a guy coming by on Wednesday that does lots of installs. But each system is different and they always jimmy things up here (scary). That's why I went through the trouble of buying everything in the US including the harnesses and having them shipped-in. I do however want to take my time to solder up everything so that it's 100% and wanted to get it done before he gets here.
    Tapping into the wires isn't a problem since I'm going to be using a harness for my car, so I can just solder it in right after the harness connection on the aftermarket part. I guess the colors specified above are for the stock wiring as I don't have GRAY or BLUE on the aftermarket harness (well I do but they are for Amp Power and Speaker).
    Nick
    trumpet's Avatar
    Jan 2011
    Langdon, ND
    32
    1,938
    48 Post(s)
    Right, the ASWC instructions refer to factory wire colors. It will make sense when you have the factory radio out of the way.
    NickCR's Avatar
    Sep 2005
    San Jose, CR
    31
    77
    Sounds great thanks for your help. Anyone on the difference on harness wires? Thinking it will be better to use the one with the gound as solid black as the orange black doesnt connect anywhere on the pioneer.
    Anyone know about 2 din installs on the pathfinder if it will require any modification to the dash panel itself?
    Nick
    trumpet's Avatar
    Jan 2011
    Langdon, ND
    32
    1,938
    48 Post(s)
    I'm a Metra dealer so I say get the Metra harness. I don't know if that one 1 makes a difference.
    NickCR's Avatar
    Sep 2005
    San Jose, CR
    31
    77
    Ok I pulled out the deck and it makes a world of sense now.
    There is a 3RD harness that connects to the radio for the steering wheel controls. Those are the ones you need to tap into. The only problem is that they are not, as easy as I didn't get a harness for it and searching around doesn't turn up a single harness for that purpose.
    Maybe someone here has some experience and can chime in on recommending one.
    You can order the Metra or Scoshe. The two wires I was concerned about don't even have connections to the car harness on the 2007 Nissan Pathfinder with stock radio. So you need to ground onto the chasis. I'll just put a longer wire and make my connections near to the radio so that I have some room to place with.
    I took some pics of the harnesses and I'll post those up after I'm done for anyone that is wondering the same thing I was.
    Nick
    NickCR's Avatar
    Sep 2005
    San Jose, CR
    31
    77
    Here are some pics of the harnesses:
    The only problem I have is that the Axxess Interface instructions don't match what I was seeing. The PINS were not in the right spots. Hopefully you can see from the pics the pin arrangement on the stock harness. Above the boxes demonstrate the stock cable configuration on the harness.
    a: Yellow
    b: Baby Blue
    c: Pink / Orange
    d: Yellow
    e: Blue
    I don't know which pin #'s those are either. But here is what the Axxess instructions says:
    Is there a harness I can buy that plugs into the SWC one?
    Does anyone know the correct configuration for the wiring on my car?
    Thanks in advance!
    Nick
  9. #9
    NickCR's Avatar
    Sep 2005
    San Jose, CR
    31
    77
    Bump.
    Anyone able to chime in on the wiring?
    Nick
  1. 2007 Dodge Nitro Amp install help
    By Pl8er in forum Wiring, Electrical and Installation Help
    Last Post: 07-28-2009, 10:26 PM
  2. Help AVH-p6400cd installing
    By SCOOBYGUY22 in forum Wiring, Electrical and Installation Help
    Last Post: 02-12-2004, 12:13 PM
  3. install help? again
    By gator01 in forum General Discussion
    Last Post: 01-24-2002, 07:14 PM
  4. head unit install help
    By <SlayeR1> in forum Wiring, Electrical and Installation Help
    Last Post: 12-24-2001, 10:26 PM
  5. need some amp instalation help
    By <baller540> in forum Amplifiers
    Last Post: 12-08-2001, 11:05 PM
