Results 1 to 7 of 7
Reload Thread: Alpine CDA-9887 and crossovers
    jaysexxin's Avatar
    jaysexxin is offline Member
    Jul 2007
    San Diego
    58
    3 Post(s)
    Good morning,
    The alpine has dip switch on the chassis for 2 xover settings; 2way and 3way. What is the best way to setup the deck with the equipment I have? Can I even do 3 way?
    Here is my setup for the speakers. I only have 1 set of speakers (i only have room for 1 set)
    Viper 550.2 components (100 RMS) - powered by MRP-F240
    MRP-F240
    40 watts RMS x 4 at 4 ohms
    50 watts RMS x 4 at 2 ohms
    100 watts RMS x 2 bridged output at 4 ohms
    I was going to bridge and have the set run at 100 watts.
    Thanks in advance
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,685
    29 Post(s)
    1134 Post(s)
    Re: Alpine CDA-9887 and crossovers
    I have mine on 2 way. Unless you are going SQ I don't see why you would have it on 3 way.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
    jaysexxin's Avatar
    Jul 2007
    San Diego
    58
    3 Post(s)
    Thanks for the response. The reason I was thinking about 3 way was because I wanted to be able to control the mids and the the tweeters individually with my deck.
    The 2-way setting only allows me to change the crossovers for the components as a whole but the 3-way gives options for both mids and tweeters. The more I think about it, it doesn't matter since the tweeters are using the components crossover HPF... right?
    Buck's Avatar
    May 2008
    Nashville
    18,685
    29 Post(s)
    1134 Post(s)
    3 way would be if you are going active, I believe.
    jaysexxin's Avatar
    Jul 2007
    San Diego
    58
    3 Post(s)
    What do you recommend for the equipment I have? 2 way?
    Buck's Avatar
    May 2008
    Nashville
    18,685
    29 Post(s)
    1134 Post(s)
    Quote Originally Posted by jaysexxin View Post
    Yep. 2 way + sub. I don't think you would gain anything by doing 3 way, but I could be wrong.
    jaysexxin's Avatar
    Jul 2007
    San Diego
    58
    3 Post(s)
    Thanks for your input!
    Anyone else?
