just try KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
1-During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
2-Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
3-for Model# XXX-XXXX and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. suppose Your code number is XXXX (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Bookmarks
