Wanting just "Bass and treble" is being redundant. The unit has a 5 band EQ for a reason. Why would you try to retard yourself by going back to only two bands of equalization?
Sell it, buy a dual.
OR read the manual and learn the eq, make the adjustments.
Whoever said change the crossover points via the eq, is a moron, you can't change crossover points via an eq.
Car audio IS an addiction.
C.A.A.A Member #1
(Car Audio Addicts Anonymous)
Refs http://www.caraudio.com/forums/buyer-seller-feedback/278560-nismos14-feedback-refs-thread.html
Take some time, tuning using the crossovers, sub level, and EQ so most of what you play sounds good then use the sublevel to adjust from there. I have a pioneer with a 16 band graphic and no specific bass/treble controls. I found once I took some time and set my EQ and filters right I rarely need to do anything with it other than tweak the sub level from time to time to suit different recordings.
And, to be particular, in my opinion you do have bass and treble controls. That would basically be a 2 band parametric EQ centered around a certain frequency in the lows and a different one in the highs. Now you just have more control over different frequency ranges in those categories.
Re: whats some good components?
Quote:
Originally Posted by deathpenalty18
Not an sq set up just want good sq speakers and tweets not interested in mids! And my sub is a fcking ia dp 18 with a memphis 4kw
Originally Posted by x1le
mids ARE speakers.
A component set = pair of midwoofer's and a pair of tweeter's
and nobody cares what your sub is.
parametric eq is where its at on this deck.had one installed today and its alot easier to work with than the 9835 lol.5 and 6 on the eq is treble,4 is mids and 1 and 2 are bass i believe.my car came with a RF system.bypassed the amp and put in a cross over for the tweets.this deck really puts out the volume crystal clear.worth every penny.i could care less about the imprint.this deck is plenty good without it.
Nissan Frontier king cab
149BT lots of voltage with this radio
SS ta 2-400 running front stage.
ID ctx69's in front doors with tweets removed/no rear stage
alpine swivel silk tweeters mounted in doors (100 rms each )
skar sk1500.1 / xcon 10 aero @ 36 has great upper end and monstrous low end.ear hurting kind ;-)
big agm under the hood,big 3 and small reikken E1000 in back
110 stock alt no problem with a UDCP
KNUKONCEPTZ wire and dynamatt extreme
Bookmarks
