Results 1 to 7 of 7
Reload Thread: Headunit Question/Debate!!
    PhattyT's Avatar
    PhattyT is offline Junior Member
    Sep 2009
    Houston TX
    Hi, I have an Alpine 9886 w/o imprint. The debate is... should I buy imprint and tune it or should I get the Eclipse 7200 mkii?
    What would you do?
    Opinions and experiences are appreciated! Any other recommendations are welcome as well.
    Thanks
    ejschultz's Avatar
    ejschultz is offline CarAudio.com Veteran
    Nov 2008
    Schererville, IN
    2,920
    19 Post(s)
    Re: Headunit Question/Debate!!
    I would sell it and get the Eclipse 7200 MKII. There's really no comparison between an "Imprinted" 9886 and the 7200 MKII.
    94 Caprice Classic LS: DEH-P800PRS, TS-C720PRS, MRV-F545, MRD-M1005, 2 REF-TM12.4 in 2.5 net cubes sealed; 97 Grand Cherokee TSi: CDA-9855, TS-D1720C, MRV-F345, MRD-M605, SWX-1043D in .54 net cubes sealed
    Resident Jeep Expert, Mother Fucker
    ejschultz's Avatar
    Nov 2008
    Schererville, IN
    2,920
    19 Post(s)
    I also just realized you're open to other suggestions. In that case, you can pick up a Premier 800/880 for pretty cheap online. I got my 800 through 6ave.com (an authorized dealer for Pioneer) for less than $350 shipped bnib.
    PaulD's Avatar
    PaulD is offline self-imposed ban
    Apr 2008
    la la land
    703
    Imprint is not that great, once it sets everything you are STUCK with it. You cannot go in and make tuning adjustments like the old H700/701.
    standard disclaimer: I know nothing ..... take my advice at your own peril
    Quote Originally Posted by SRim23 View Post
    i think we're between boners at the moment
    nineball's Avatar
    nineball is offline too many toys...
    Feb 2008
    home
    1,921
    Quote Originally Posted by PaulD View Post
    that is not the case. if you use the auto-tune feature once it is done tuning you are stuck with that setting but you can manually set up the imprint as you like and make changes any time you want to.
    Quote Originally Posted by eharri3 View Post
    I have 4 12s getting 2K watts rms and my front stage is 4 Walmart JVC coaxials running off 16 watts rms of head unit power. My sub sounds fine but my mids and highs don't sound very clear and start to distort long before my subs do. Anybody know why? Any suggestions?
    PaulD's Avatar
    Apr 2008
    la la land
    703
    really ? I was told no, so it was never even a consideration for me
    nineball's Avatar
    Feb 2008
    home
    1,921
    i was told the exact same thing until i called alpine directly. with the x100 and the imprint you can manually set everything. there are 2 types of imprint kits.
    the imprint that goes with the ida line must remain connected to the unit at all times for it to work. you can set it manually and adjust as you like or auto-tune and leave it on that setting.
    the other imprint (for the 9887) must be connected to use but once you auto-tune the settings are stored in the head unit and the imprint can be removed.
