Results 1 to 3 of 3
Reload Thread: External Drive on CDA-9886
    bizzy07's Avatar
    bizzy07 is offline CarAudio.com Elite
    Oct 2005
    IA
    24
    613
    I have a 40 gig Travelstar IDE 2.5" laptop hard drive just laying around and want to use it in a hard drive case in my car. The cables that come with the cases have two usb's on one end and one on the other. I was wondering if the 9886 would supply enough power for the hard drive or will I fry it? If anything I guess the hard drive was free and the case is only like $6 shipped so I won't be out much, but I don't want to hurt the head unit
    Alpine cda-9886
    AQ2200d
    18" HDC4
    AQ 4x90
    First gen AQ Components in front and rear doors
    Optima 34/78 yellow top up front
    4 runs of 1/0 Knu KLMX Kable and Big 3 done in 2/0 welding wire
    REFS: Crzy, dleccord, Steet DreamsCC, perfecxionX, Seattle206, infamous_e46, Goindef154, 2 avalanche 18s, wgsj_fortvalley, chargdbassbuick
    AlterEgo99's Avatar
    AlterEgo99 is offline Streaming consciousness
    May 2009
    Domie Homie
    12,623
    19 Post(s)
    Re: External Drive on CDA-9886
    I don't think you will fry anything...typically if the USB accessory requires a high powered USB port, it simply will not turn on. If it does power up, I am not so sure that your HU will recognize the HD anyways. Worth a try.
    Eddie Izzard: Squirrels always eat nuts with two hands, always two hands, "arararar", and occasionally, they stop and go...oh, uh, ah, as if they're going, "Did I leave the gas on? No! No, I'm a fucking squirrel!"
    Tehgregzor's Avatar
    Tehgregzor is offline Enjoys loud noises.
    May 2005
    Murray,KY
    25
    1,355
    yeah, USB's a really good bus. Its not very fickle, and rarely do they just "burn out." Either it works or it doesn't. I would give it a shot. Make sure your headunit has really strong POWER and GROUND connections.
    2004 Jeep Grand Cherokee Special Edition AWD
    Rebuilding from scratch...
    Deadened and Polyfilled still at least.
